Need help on water leak!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-05-2006, 06:57 PM
fleastang fleastang is offline
fleastang is starting off with a positive reputation.
Unhappy Need help on water leak!!
I have a 99 F-250 Super Duty 4WD and here lately when it rains alot I have alot of water getting in on the passenger side floorboard coming from somewhere under the right front under the dash. I have looked under the cowling and don't think it is from there. I heard of someone having water funnel in from the 3rd brake light gasket and I did replace that because it had some leakage but after last nights heavy rain it has soaked my carpet again. Once i dried it I drove it and lots of water came from somewhere and completely soaked a bath towel. Anyone think it may be from the heater blower area and filling up the box under the dash till it runs out??? Any ideas on fixes?? Thanks for any HELP!!
Old 09-05-2006, 07:09 PM
crazyrwe's Avatar
crazyrwe crazyrwe is offline
crazyrwe is starting off with a positive reputation.
I usually just get under the dash and close the door,and let someone run a garden hose with no attatchment on it in various places.Do it slowly,and if it gets tough,mix up some food coloring in a bucket or 2 and try that. Al.
Old 09-05-2006, 07:18 PM
Looks like more rain so mother nature my do it for me. I wondered if there was a way water was entering the blower housing somehow. Thanks for the info crazyrwe.
Old 09-05-2006, 07:21 PM
Cuda444's Avatar
Cuda444 Cuda444 is offline
Cuda444 is starting off with a positive reputation.
I've had this problem in the past also... never found the answer though. And, knock on wood, it has stopped... Hasn't done it for months now, which is fine with me... But I still gotta get in there and replace the insulation under the carpet.
Let me know what you figure out!
Tom
crazyrwe's Avatar
Fleastang,just a dumb question. Are you sure it's just water,no antifreeze.Are you running straight water in your cooling system? I was thinking maybe your heater core?
Old 09-05-2006, 08:06 PM
No it is just rain water. No antifreeze to be seen or smelled. It is just clear water and only after we have our gully washer rains here of lately. After I dried it up, I layed a towel down under the carpet and mats to try and absorb some of the moisture in the padding and when I took off under hard acceleration (and uphill) it came out and completely soaked the towel which makes me think it may be leaking into the plastic housing area maybe thru the blower where it attaches at the firewall.............I am at a loss right now.
Old 09-05-2006, 08:07 PM
bobbo7915 bobbo7915 is offline
bobbo7915 is starting off with a positive reputation.
ha i have the same problem with my '99 crew cab, the passanger floor is slighty damp but under the sill plate is soaked, its not anti-freeze but just water. its just in the front so its not the third brake light gasket. im gonna have to look into it more and see what i find.
Old 09-05-2006, 08:18 PM
Sounds exactly like my problem. Under the sill plate it is full of water every time I notice the leak. I know it is rain water but how it comes in is a mystery; I just know it is coming from under the dash somewhere. I may have a windshield person look at it.
Old 09-05-2006, 10:01 PM
Cuda444's Avatar
Are you guys leaving your blower on something other than off when the truck is off and parked during the rain? Like defrost?
Just curious
Tom
Old 09-06-2006, 05:38 AM
I always turn off the blower in regards to the defrost/vent control. I have noticed that the off position leaves the door under the dash at the blower open to where you can see the "squirrel cage" of the blower fan visible thru the upening. I can post pics if needed....................
Old 09-06-2006, 07:31 AM
Studenut65 Studenut65 is offline
Studenut65 is starting off with a positive reputation.
I had the same problem. I would get water sitting in under the door sill plate. I culked the windshield better, but the leak persisted. It seams that the carpet on the passenger side would absorb the water from the sill...I think. Anyhow, I had the rear light sealed and the rear window checked for leaks. Well, I found the leak, but it wasn't the window or light. It appears that the welded seam at the back of the cab leaks water and it runs right down to the sill plate/carpet. I pulled out my entire interior one weekend and ran a garden hose over the rear seam. When I saw it leaked, I used culk (black on my black truck) and culked the seam on the outside. Don't culk on the inside b/c water will sit in the seam and rust it out eventually. Let me know if I can be of more help.
Nate
Old 09-06-2006, 11:19 AM
see the rear of my cab is dry, its only the front. would leaving the blower on something other than off cause it to leak? i guess if it was taking outside air in.....
Old 09-06-2006, 11:46 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Make sure the AC drain is clear. If water runs in the air intake, it has to drain out the bottom of the AC box, otherwise it fills up, and runs into the passenger compartment.
At least, that's what it did in my '97 Cougar
Old 09-06-2006, 03:21 PM
Where is the A/C drain located? I know water drips from the passenger side for the A/C but where the drain is I am not sure. I do know it is rain water from the quantity and I wondered about the air intake (if that is what is under the cowling on the passenger side) and it sealing with the "air box" underneath in the engine compartment where the blower motor housing is located. At that point I wondered if water was getting in the blower housing (squirrel cage area and beyond). Just an idea since it is getting at least a quart minimum of water coming in after a heavy rain......................thanks for the replies thusfar!!
Old 09-06-2006, 04:19 PM
If you pull your kick panel off and your carpet back, can you run a hose over the windshield and down over the air box under the hood to see if there are any "streams" of water? Just a thought. I have a regular cab, that is why my front carpet got soaked with a rear cab leak. Sealing the top of the windshield cured my front leak for the most part. Im interested to see where you will eventually find the leak.
Nate
2013 F150 Wet drivers floor Shabba107 2009 - 2014 F150 3 12-13-2016 09:07 PM
windshield leaking ? gman97005 1968-2013 Full Size Vans 14 01-24-2016 08:04 PM
1994 F150 - Cab Leak Demonhawk 1987 - 1996 F150 & Larger F-Series Trucks 18 11-13-2015 09:58 PM
Floor Mats are Soaked Steely Dan Escape & Escape Hybrid 11 12-04-2006 08:47 PM
96 bronco water intrusion GODADONE 1978 - 1996 Big Bronco 14 06-04-2003 02:47 PM
Tags
cab, clearance, f250, f350, ford, iof, leak, leaks, lights, pass, passenger, rain, sd, side, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
