1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need help on water leak!!
Old 06-26-2012, 06:47 PM
Mud-and-Guts's Avatar
Mud-and-Guts
Mud-and-Guts is offline
Its been over a year since I replaced the third brake light and I have not had any water in the cab since. That seal must have been my problem.
  #62
Old 06-26-2012, 06:55 PM
brosko80's Avatar
brosko80
brosko80 is offline
Oh ya it probably was your problem but there many others who have this problem with water entering the fan box and then the cab.
I am just saying how i think water gets into the box.
  #63
Old 06-26-2012, 07:14 PM
Mud-and-Guts
Not disagreeing with you just posting up my issue and its fix! The third light seal was bad allowing water to leak into the overhead and run down into the box. I am sure there are other ways it could enter but this was my issue. My issue was worse when facing down hill.
  #64
Old 06-26-2012, 07:22 PM
brosko80's Avatar
brosko80
brosko80 is offline
Oh that is interesting. I didnt realize that it ran from third brake light to box. I guess there are many ways water can get in a vehicle. When you think about it its amazing that water can be completly kept out of a vehicle.
H2o always finds a way in.
  #65
Old 06-26-2012, 07:45 PM
Mud-and-Guts
I never would have thought about it but I just installed an ebay cheap brake light and was not liken the looks of the seal. then just days later my wife had water hitting her in the feet and I could hear it sloshing in the box, so I replaced the light just to check and it fixed my issue
  #66
Old 06-26-2012, 08:13 PM
brosko80's Avatar
brosko80
brosko80 is offline
Wow quite a story. Just goes to show you, you never know!
  #67
Old 03-21-2015, 09:08 PM
Parts Jimmy's Avatar
Parts Jimmy
Parts Jimmy is offline
So let me get this straight. The 3rd brake light on the back of the cab was allowing water to drain all the way to the front of the truck and into the fresh air intake where the blower motor resides? I just drilled a hole in the bottom of my box. 3rd brake light? Thanks!
  #68
Old 04-13-2015, 01:41 PM
mstelly's Avatar
mstelly
mstelly is offline
I am having the same problem underneath the glovecompartment there's a black blower box that runs into the firewall. Where the firewall and blower box meets gets wet everytime it rains and has my passenger side carpet wet. Any suggestions would really be appreciated. But its definitely coming from where the blower box and firewall meets under my glove compartment. Any fixes please advise..thx
  #69
Old 09-03-2016, 03:40 PM
1tonner's Avatar
1tonner
1tonner is offline
Thanks to Hurricane Hermine Id like to add some info to this thread as it took me a few years to diagnose a simple issue. First my leak was the heater box filling with water from rain and splashing out when driven soaking the pass floorwell. It was said by fleastang to drill hole in heaterbox, when I thought to only check the evap drain. Simple, pull back the inner fender liner and 3/8 hole and your water will pour out. Ultimately the incoming water from fresh air vent is difficult to reseal so this is a good fix. THANKS FLEASTANG
I also had water under the rear seats and after pulling the seatback and testing thinking it was the window it was the vents that let the doors shut easily. The foam seal isnt working any longer and coulnt get them out so I pushed them toward bed and silicone caulked them. Not pretty but works!
Everyone likes pics so>>>
  #70
Old 05-08-2017, 07:02 AM
pennsylvaniabo's Avatar
pennsylvaniabo
pennsylvaniabo is offline
Is drilling a hole the best/right way to solve this?
tpolley
01-04-2023 11:39 AM
rghouse
11-03-2017 04:25 PM
Slick 66 f100
10-30-2017 09:30 PM
fordf2501
01-04-2017 08:57 AM
Shabba107
2009 - 2014 F150
12-13-2016 08:07 PM
Quick Reply: Need help on water leak!!
