obd code PO299 - Ford Truck Enthusiasts Forums
obd code PO299
Old 09-05-2006, 04:25 PM
scarecrow673 scarecrow673 is offline
scarecrow673 is starting off with a positive reputation.
obd code PO299
My 05' 6.0 has a check engine code po299 which is turbo underboost.The light came on yesterday while towing my camper.Truck is running fine,what do you guys think, needs a turbo ? I hope not only 37k. HOPEFULY SOMETHING LESS EXPENSIVE.
Old 09-05-2006, 04:40 PM
catalinagoose catalinagoose is offline
catalinagoose is starting off with a positive reputation.
A P0299 could be caused by a failing or failed turbo among other things. More likely your EBP sensor is biased. The EBP should have a pressure reading of approximately 14.5 psi at sea level with the key on and engine off. You need a scan tool to check this. If the EBP pressure reading looks ok, I'll usually begin investigating a turbo related cause for this code.
Old 09-05-2006, 06:04 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
why are you worried about expense? its under 5/100000.
Old 09-06-2006, 03:16 AM
2006f350fx4 2006f350fx4 is offline
2006f350fx4 is starting off with a positive reputation.
i was told that the turbo is not covered under the 100000 mile. because it is bolted on. the eng's internal parts are the only think covered. after 36000 you are s.o.l.
when i bought the truck they even told me that you have a 100000 on the DRIVETRAIN. think that there is something fishy here. good luck
Old 09-06-2006, 06:14 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The turbo falls under emissions and IS covered. Your dealership is WRONG and needs to recheck it's facts or they are trying to rip you off. There is a recent thread about this (within the past 10 days) about what you have to pay. 100 dollar deductible at MOST. Powertrain isn't on 100000 unless you bought some kind of extended warranty.
Old 09-06-2006, 09:55 PM
rockcod rockcod is offline
rockcod is starting off with a positive reputation.
I had the same code pop up on my 05 f350 ps 4x4, it turned out to be the turbo solenoid/VGT. It prevented the turbo from making full boost. It was a 1 day turn around to repair and it was covered under warranty. Just another option of what it could be. Good luck.
Tony
Old 09-07-2006, 01:05 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03 SoCalSuperDuty03 is offline
SoCalSuperDuty03 is gaining momentum as a positive member of FTE.SoCalSuperDuty03 is gaining momentum as a positive member of FTE.
Like Catalina said... I was told my truck needed a new turbo (2nd time, under warranty) just for giggles grabbed a PDA and checked baro readings, BAM, EBP reading
20.68 KOEO. New EBP sensor and three wire harness, now reads 14.5. Evidently didn't need a turbo.
Tim
Turbo farts 2006 6.0 L not much power. dmjm5 6.0L Power Stroke Diesel 11 09-02-2011 12:02 AM
2006 f250 code po211 and po611 any help would be great!!!!!!!!!!!!!! johull 1999 to 2016 Super Duty 10 11-08-2009 05:47 PM
2006 f-250 error codes po299 and po611 any help would be great!!!!!!!!!!!!!!!!!!!!!! johull 6.0L Power Stroke Diesel 16 11-08-2009 02:02 PM
Trouble code PO299 Turbo charger underboost Jim83 6.0L Power Stroke Diesel 5 08-04-2009 07:41 AM
SuperCharged Turbo Underboost, code PO299, means what? strf12 1999 to 2016 Super Duty 3 04-29-2009 05:59 PM
Tags
2004, 2005, 2006, 304, 350, 60, code, diesel, f250, f350, ford, obd, po266, po299, truck, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
