factory cb radio - Ford Truck Enthusiasts Forums
factory cb radio
Old 09-05-2006, 03:09 PM
alie-r's Avatar
alie-r alie-r is offline
alie-r is starting off with a positive reputation.
factory cb radio
hello
i have a factory cb, and i will instal it in the pickup.['78 supercab]
i don't know what the exact location is.
i don't know where i can conect it, i can't find a conector that fits on these.
it's a 4 point conector with a yellow/black ,lightblue/brown wire end two thin wires lightblue/red and darkblue/red.
did anyone know what is the +/- and witch are for the speaker?
sorry for my english, i com from the netherlands.
andre lier
Old 09-05-2006, 03:47 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The Combo Radio/CB radios mounted in different places in different years .
Do you have a picture of all the CB related equipment you have to show me ?
The +/- is probably volume.
Which is for the speaker ?
That should pull into the back of unit as it is also works with the regular radio.
Does it look like this ?
Old 09-05-2006, 05:26 PM
alie-r's Avatar
yes that is the cb radio.
there is a big metal box with a 10 ft wire that go's to the conector for the mic and there is the 4point conector.
andre lier
Old 09-05-2006, 05:58 PM
Okay, the Box goes behind the seat and the cord that hooks to the microphone goes under the carpet to mount to dash. then the mic cord plug in,like you see in the picture.
The antenna cable would then hook-up to the box and that cable would feed to where you mount the antenna (s)
Do you have a digital camera to take a picture and post it for me ?
Old 09-05-2006, 06:01 PM
Alie.
This is from another thread.
Quote:
Originally Posted by 81-F-150-Explorer
the early 80's ones were located under the driver's seat. Just about directly under the driver. (Bench Seat)
The Cb was located on, or in the center console for Buckets.
On the 1979 ford wiring diagram,
I'll provide the connector #s for reference if you have a Ford wiring diagram handy. the numbers will not be located on the truck itself.
The Yellow/Black wire that hooks power to the factory Radio, is where the power to the CB comes from.
On trucks without the CB option, the radio plugs into the main harness radio connector. (Connector-506 or 506A)
On trucks with the CB Option, but without the stereo radio...
#1: A harness extention hooks to the main harness radio connection (C-506-A). From there it goes to the radio connector (C-506) where another yellow/black wire splits off from that connector.
#2: Follow that yellow/black wire and you will come to another connector (C-530) where another harness extention plugs in. From Connector (C-530) one wire goes to the CB Reciever/Transmitter Radio. at connection #(C-532). The other wire goes to the CB Radio microphone.
The speaker is connected into the radio speaker harness that goes to the dash.
On trucks with the AM-FM stereo, and CB.
#1: A harness extention hooks to the main harness radio connection (C-506-A). From there it goes to the radio connector (C-530) where another yellow/black wire splits off from that connector.
#2 The Radio connects to this Connector (C-530) while the other goes to a C/B radio suppression choke, that's spliced in (Splice #503 (S-503) ) After the splice (S-503), the wire changes color to black goes through the choke, and hooks to another harness extention at connector (C-530).
#3: From Connector (C-530) the wire changes back to yellow/black and splits off. One wire goes to the CB Reciever/Transmitter Radio. at connection #(C-532). The other wire goes to the CB Radio microphone.
The Cb Radio is hooked to the Center speaker located inside the dash. and is seperate and not hooked into the door speakers.
Hope this helps.
Old 09-06-2006, 11:48 AM
alie-r's Avatar
i have a AM/FM stereo radio,butthats not the same connector if on the cb wire.
andre
Old 09-06-2006, 07:31 PM
That's because That unit is out of an 80's truck.
Where's the picture of the 80's stereo/radio that came with the microphone and wiring ?
Old 09-07-2006, 01:01 AM
alie-r's Avatar
http://img215.imageshack.us/img215/3408/dsc02800ln9.jpg
thats the metal box and the am/fm radio is the same as on the pic you shown in your first reply.
if y remove the 4point connector, can i put the yellow cable's to the + and the blue at the -?.
the thin wire's are for the speaker?.
in your third reply they said the cb is under the driversseat. mounted on the floor?
and the wire? onder the carpet?
andre
Old 09-07-2006, 02:14 AM
Can you read of any Ford label info on that radio box?
If so please post it.
Looking for an D7??-?????-? type number
It appears from my schematic that the wiring you have on your unit is wrong for the 78/79 truck.
Also, did you not get the radio from where the CBbox came from ?
From the looks if it you are trying to fit the CBRadio that you got into a AM/FM Stereo that doesn't support that CB Radio box.
Your wires show a 4 wire connector with:
Blue/Red
White (looks like white in the photo)
Lt Blue/Red (Radio Light)
Yellow/Black (Power)
Then the 78/79 also shows ONE yellow/black wire going to the CB Radio box
with another 4 wire connector for speakers
Brown or Orange (They are smudged letters) looks like BR or OR
Black/white
One goes to speaker ground
The other one goes to speaker +
The 1980 CB Radio box shows a bunch of wires (8-9) going to it via that black connector that yours shows.
Plus a 4 grey connector to the back of the AM/FM Radio with:
Blue/Green
Yellow/Black (power)
Green/Red
I'll see if I can find a an 1980 CB radio schematic
Old 09-07-2006, 11:07 AM
alie-r's Avatar
on top of the box D.O.C type approval
number 109365208
D.O.C type C5FD8800 series
moterola inc
on the side with the connector under the fuse 9071
under the antennaconnector 198002
on the underside moterola inc
fcc transceiver data cb 1134
ford
remote cb
type accepted for part 95(d)
certivied per part 15c
thats all that i can find on the cb.
is it not possible to instal the cb without the radio?
do you need a special radio for a cb?
the radio in my truck is orginal and i have the cb from ebay.
my truck didn't came with a cb.
andre
Old 09-07-2006, 01:12 PM
According to the wiring schematic Ford had 4 different radios available.
That CB Radio you have that you bougth off Ebay will only work with the special Combination AM/FM MPX stereo CBRadio from a 1980 Ford truck.
IMO, If you wanted a CB Radio, you should have just bought a "stand alone" CB Radio .
How much did you pay for that set up ?
I may be able to help you out.
Old 09-07-2006, 02:51 PM
alie-r's Avatar
i sell it as an '79 truck oem cb radio for $39
can i put a '80 radio in a '78 dash?
andre
Old 09-07-2006, 03:12 PM
So you are saying you bought it on Ebay for $39.00 ?
80 radio in 78/79 ?
I donlt think so but.
Good question.
Why not just get a Regular CB Radio and mount it under the dash?
I am sending you a Private Message about this CB Radio you have.
Old 09-07-2006, 03:40 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
It looks like with the info given here, that he may not have the wiring harness extention that goes from the main harness radio power connector, where it splits off, one goes to the cb, and one goes to the music radio.
According to the late 70's wiring diagram, (Mil1ion posted it for me earlier up the thread) for the CB, on a truck with a stereo radio, the CB has an isolated center speaker, that is not hooked into and is isolated from the stereo.
On trucks with mono, AM or AM/Fm, there is an interupter placed in the speaker wires from the mono Radio, and the CB and Mono radio share the center speaker.
I think he's missing a harness extention.
1989 F150 5.0 - Fuse link D? Unaffiliated 1987 - 1996 F150 & Larger F-Series Trucks 2 04-17-2016 02:39 PM
Bad new mlps? chucks123 1987 - 1996 F150 & Larger F-Series Trucks 1 03-02-2016 01:04 PM
How-to: 1999 Super Duty to 2004 Explorer Steering Wheel Swap SuperHatch 1999 to 2016 Super Duty 7 01-07-2015 02:03 PM
EBPV Sensor Location KH85 1999 - 2003 7.3L Power Stroke Diesel 6 08-05-2011 05:37 PM
78 f-250 ebrake cable where can i get one at? 1978fordf250 1973 - 1979 F-100 & Larger F-Series Trucks 8 06-05-2005 12:50 PM
Tags
109365208, 1134, 1979, amfm, c5fd8800, cb, data, factory, fcc, ford, harness, mono, radio, series, speaker, transceiver, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
