Avatars - Ford Truck Enthusiasts Forums
Avatars
Old 09-05-2006, 08:21 AM
93F250's Avatar
93F250 93F250 is offline
93F250 is gaining momentum as a positive member of FTE.
Avatars
I am not sure where I am going wrong but every time I try to load an avatar, it tells me the selected file is not a jpeg or whatever so I double check the address and everything is right. Am I doing something wrong?
Old 09-05-2006, 11:06 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Sounds like you don't an an acceptable file for FTE use.
What is the end tag of the file you are trying to upload ?
bmp,gif,etc ?
You need to make sure it is no larger than 60 x 60 px and in an format FTE will accept.
Old 09-05-2006, 02:26 PM
93F250's Avatar
bmp,gif,etc ?
All right. I will answer these 1 by 1.
1. The pictures I have tried are of police cruisers or dogs. Nothing that I would deem inappropriate especially given some of the avatars I have seen.
2. The end tag is jpg.
3. All the pitures I have tried were 60x60 pixels or less.
I hope this will help.
Old 09-05-2006, 03:05 PM
Are using the browse feature in the "Edit avatar" area of your CP to upload the pic?
Or are you trying to use a pic from some other source ?
Old 09-06-2006, 07:38 AM
93F250's Avatar
I was trying to get them off the internet.
Old 09-06-2006, 03:17 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Download them to your machine then upload them.
Old 09-06-2006, 03:34 PM
93F250's Avatar
Thanks for the help. I took Torque1st's advice and it worked.
Old 12-05-2006, 12:21 PM
Totoro's Avatar
Totoro Totoro is offline
Totoro is starting off with a positive reputation.
I have a .JPG file that is 60x60 pixels (2.39Kb). I tried loading the picture from my PC and I get the following error:
Parse error: parse error, unexpected $ in /data/httpd/ford-trucks.com/htdocs/forums/includes/functions_upload.php on line 395
Any suggestions?
Old 12-05-2006, 04:30 PM
NH-Hottie's Avatar
NH-Hottie NH-Hottie is offline
NH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud ofNH-Hottie has much to be proud of
Totoro. I've been having the same problem. I thought it was just me, and I was going to wait awhile to see if it works itself out. Maybe someone else will pipe in.
Old 12-05-2006, 08:10 PM
Again, People should be awares that certrain areas of FTE may be Offline or shut down so more important areas will have full resources during maintenance ...which can happen at any time.
When the boss is working on installing a new server or data base, the last thing he may be worried about it the User Gallery or avatar uploading.
He needs those resource being used by them to do the other work.
If over 10 days at 24/7 ... the situation doesn't change..then there is something to worry about.
Think of FTE's operation and certain features being down ....like arriving at the dry cleaners at 11:00 am only to find a sign on the door that says:
Gone to the bank for change..be back in 10 minutes
Old 12-06-2006, 07:27 AM
NH-Hottie's Avatar
That's what I figured Mil1ion. I wasn't too concerned when I noticed the problem on Monday. I figured if it goes past a couple of weeks, then there really is a problem.
Thanks for the info.
Old 12-06-2006, 10:06 PM
Totoro's Avatar
Well it seems to be working again. Thx!
Totoro
Avatar V10ZILLA S. California Chapter 3 11-21-2010 12:56 PM
Avatar Is Killing Me!! redvipss User Gallery & Picture Display 17 12-21-2007 12:00 PM
My Avatar 61Canuck Manitoba / Saskatchewan Chapter 15 01-26-2007 09:14 AM
Was lookin Custom Avatar zigsgt User Gallery & Picture Display 6 03-16-2006 04:52 PM
Tags
avatars, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
