Speedo Reprogram! - Ford Truck Enthusiasts Forums
Speedo Reprogram!
Old 09-05-2006, 12:07 AM
Fordman_Evs Fordman_Evs is offline
Fordman_Evs is starting off with a positive reputation.
Smile Speedo Reprogram!
Ya'll,
The other day I was firguring out my gas mileage and I was shocked a horified...10mpg. I did a complete tune up and pulled no codes I was at wits end then it hit me. The pervious owner had changed out the OEM tires in exchange for 31x10.5x15's "years ago". I checked the PSOM as per the instructions on FTE and sure enough it said 972 CAL and from what I understand that is the correct number for stock size tires. I was going to reset it and I ran into two problems...1) I could not understand the instructions on how to do it... 2) And couldn't find the rev's per minute for my tires (Yokohama Geolander H/T-S) but I assume they are close to 9.18
Can anyone help with these two problems.
Cheers,
Evs
Old 09-05-2006, 04:22 PM
Cheggie's Avatar
Cheggie Cheggie is offline
Cheggie is starting off with a positive reputation.
I found the rev's per mile on Tirerack for your 'yokes, and it's 680. According to the FTE article about reprogramming, the new calibration constant should be 9.18.
To reprogram it, you have to ground the wiring connector under the dash, directly under the glovebox. I used a test lead with little aligator clips. While holding the reset button on the odometer, turn the key on, but not running. Press and release the reset button again to display the cal. constant, then use select to change the constant. Press and release reset one more time to lock it in. This can only be done a total of 6 times ever with your current PSOM, so do it right the first time! If you chicken out, you can shut the key off before the final press of "reset."
I found that I didn't get a good ground the first time, and it wouldn't let me change the constant.
EV2 Pyro Question.. schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 6 09-17-2013 07:33 AM
Swapping Isspro EV's for EV2's? Km1210 1999 - 2003 7.3L Power Stroke Diesel 9 11-22-2012 11:53 AM
Isspro EV2 fuel gauge install Baxdoc Electrical Systems/Wiring 4 04-03-2011 05:34 PM
Issopro EV2 Install Problem. Bobbys Big Red Rig 1999 - 2003 7.3L Power Stroke Diesel 12 10-07-2010 09:18 AM
4.10 on 31's? Fordman_Evs 1987 - 1996 F150 & Larger F-Series Trucks 19 01-10-2008 01:27 AM
Tags
1995, 96, 972, cal, code, dash, f150, ford, odometer, oem, psom, ranger, reprogram, reset, showing, speedo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
