7.3 oil pressure switch location - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-04-2006, 05:08 PM
gratefuljed gratefuljed is offline
gratefuljed is starting off with a positive reputation.
Spending labor day readin and working on my 2000 7.3. Also did a search to no avail. My fuel pump is not working, I think due to the oil pressue switch not working. Bought a switch at napa - did not get the service manual - should have cause I cannot for the life of me find the location of this switch, at least the one I bought. Any help out there today? Thanks very much,
John
Old 09-04-2006, 07:09 PM
KRAZY KRAMER KRAZY KRAMER is offline
KRAZY KRAMER is starting off with a positive reputation.
before you go replacing things (which i have done also and didnt help the situation) i would start at the root... the pump itself... just go under the driver side right under the door and locate the fuel pump on the inside of the frame rail with a test light... you will probably need someone to turn the key for you because you might not get under in time before the relay cuts it off... just pull the boot back on the end of it and hook up the test light to see if it has power... if it does and its not running the probelm is the pump or the ground.... as for the oil presure switch im not sure what your saying....if its the sender you are talking about its right on top of the motor.. sticking straight up with a black connector on it... its right in fornt of the fuel filter if your lookin at the motor from the front... good luck
Old 09-04-2006, 07:39 PM
Thanks - the pump is running but no gas is coming out. My oil pressure guage does not come up so I was thinking it was the sender. I also understood that if the sender is not working it would cut off the pump, but the pump is working so I am totally confused - not unusual. On a side note, Napa sold me both the wrong oil sender and a wrong speed sensor so I will be back at it tomorrow.
Old 09-04-2006, 07:47 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
What kind of Motor Do you have (no gas coming out)??? and where is no gas/fuel coming out?
If it is a diesel
There are 2 oils systems Low Pressure and High Pressure
Low - feeds engine for lubrication and fills High Pressure Resevoir
High - Provides High Pressure Oil to drive the injectors
Niether should shut off the Fuel Pump
Old 09-04-2006, 08:29 PM
im sure he meant fuel...but that is a good question... at which point in the fuel system did you check to see no fuel was coming out... right at the discharge of the pump?.. if so i would dump a can of fuel in just for insurance before you waste 200 bucks on a pump and the labor... you cant trust your fuel gauge in a situation like that... and amiller is exactly right about the two oil systems... and back him up 100% that a bad sender will never shut down the fuel system
Easy Brake Switch Location? BaggedMerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-12-2015 09:36 AM
7.3 Doing some strange things rv7plt 1999 - 2003 7.3L Power Stroke Diesel 5 09-05-2014 08:39 AM
Posting from John Wood's WiFi gabeyd Excursion - King of SUVs 10 10-26-2013 05:01 PM
Hello from Vegas John in Vegas New Member Introductions 4 09-25-2013 04:07 PM
HELP! 99 f250 4x4 trans will not shift into 4th GreenTerracePSD 1999 - 2003 7.3L Power Stroke Diesel 19 07-29-2012 02:11 PM
Tags
2001, 73, f250, ford, location, oil, pressure, sensor, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
