Homemade tool for holding the harmonic balancer
http://www.panix.com/~alvinj/file12/...icbalancer.jpg
It was going to be a knife, that's why the file is bent "side ways".
The holes are simply 13/64" holes spaced just right to allow 3/8" bolts to be slipped through the harmonic balancer and through the file both.
It's not "tight" in use, just "captive".
Works great, add a cheater pipe if needed, the only time I used it (about a month ago) I didn't need a cheater pipe.
While I'm at it, here's my T18 guide pins...
http://www.panix.com/~alvinj/file12/guidepins.jpg
7/16" x 5+1/2" long grade-5 bolts with the heads cut off and other modifications for the fun of it. First used for that in late '78 and last used in mid '06.
Alvin in AZ ('75 F150)
I have to say, ARE YOU NUTS? A file is hard and brittle and will shatter under any flexing, bending or side force, it can send out sharp fragments into your eyes not alone the jagged broken end that will eat human flesh. Just typing about this gives me the chills and with a cheater pipe. Please don't post items like this as we don't want injured FTE members. Not picking on you just that a friend back in the 60's used a file for a pry bar, it snapped with a file fragment taking out his eye at 16 years of age he is now 57.
The only question I have is how the hell did you drill holes thru a file?
.....=o&o>.....
.....=o&o>.....
.....=o&o>.....
.....=o&o>.....
I feel that Carl did bring up a valid point. We have a group with diverse backgrounds and abilities here. Not everyone will understand what they are looking at, not all of those will bother to find out what they are looking at. We have to keep them safe long enough to learn inherent risk.
That aside:
Interesting idea, I've been brainwashed to get out a socket, maybe a prybar. Now I wouldn't think to do anything different.
Will you create a gallery and upload that pic of the guide pins? I described them to someone a few weeks ago, would have been nice to pin a picture to the post.
Have fun out in that shop, Mike
LMAO! He bent it to make a knife? He put holes in it? It's not a file any longer!
Carl wasn't thinking about it; I have seen him use the word anneal in a post or two.
Problem is having a newb just look at the picture and get hurt. I had the good fortune to be surrounded by people who looked after my best interest. A few decades later the shoe is on the other foot... Was I that scary?????????? DAYAAAMMM!!!!!!!
on
1 Post
Yep an engineering idea on the harmonic balancer holder... I have too agree with Carl and Mike..on this one..The use of the File is scary! to say the least....
I would use a piece of flat stock ..after you drill your holes in location..Heat it up with a torch and quench it in Oil for about 10 seconds (depending on how thick the material is..this will case harden it.. and make it a safe tool to use...
Like as mentioned above..we get some younger guys in here that dont have a background in NDT or Metallergy, Sonic and X-Ray or particle testing....and they might have the tendency to take what everyone posts as being tested to ISO 9000 criteria or MIL STD 105?
But all in all neat Idea!!! JMO..
RJ
RJ
LOL
Sorry about not explaining the fact that the file had been "normalized". :/
(I guess a guy could call that a type of annealing and not be too far off)
FiNgured that would be obvious with the bend and the holes tho.
(trying not to beat anyone over the head with stuff they already know)
Had it as part of the post but I'm a windy sucker and try to go back and weed out and edit stuff, that was something that got weeded out.
Started out with a hunk of bed frame (steel that's properties are comparable to a wrench or screwdriver) that already had a hole in it, but would have to have some of the perpendicular part (angle iron) removed if a guy wanted to use two holes instead of one... and had a plie of old files I'd normalized...
I didn't get anywhere near needing a cheater bar/pipe when I recently removed my timing chain cover but YMMV with all that rusty-nasty stuff some of you have to deal with out there.
The file is a Nicholson "made in usa" I have over five-dozen old files and a dozen hoof rasps to make knives (etc) from, none of them say China on them, Austria, Sweden and England, but no China, sorry.
I spark tested a file that was stamped China, once tho... it sparked the same as all the rest, no soft inner core or anything like that, just pure 1 to 1+1/4% carbon, plain carbon steel.
A railroad rail is a normalized piece of high carbon steel, like the top half of a cold chisel, so that file is a lot like them that way.
Alvin in AZ
ps- I'll have to figure out how to set up a gallery, I'm new to website forums unix/tin/newsgroup junky here :/ rec.knives, alt.crafts.blacksmithing ...I ain't a blacksmith tho! :/
Alvin in AZ
