Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-03-2006, 11:02 AM
whatstar1117 is starting off with a positive reputation.
94 3.0 shorty pcv valve
hello everyone; first post. Can anyone tell me what the function of the upper vacuum line (smaller of two) is on pcv valve?
  #2 (permalink)
Old 09-03-2006, 11:05 AM
RangerPilot's Avatar
<-- Private Pilot
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
They're both to supply crankcase vapor to some other point on the engine. Where's it go?
  #3 (permalink)
Old 09-03-2006, 11:22 AM
The lower hose goes to an intake manifold vacuum source, I'm pretty sure. The upper pcv hose which is cracked, goes to what I think is called orifice valve to regulate the amount of vacuum seen by the upper port on the pcv valve. Guess the question I should have asked is why two hoses on the pcv valv?
  #4 (permalink)
Old 09-03-2006, 11:55 AM
Mormakil is starting off with a positive reputation.
M
  #5 (permalink)
Old 09-03-2006, 03:22 PM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
Hi Whatstar1117
First, welcome to our FTE forum
The upper connection on the PCV valve goes to the solenoid valve which connects to the Charcoal Canister at the other end.
However, on some Aerostars, depending on the model year, the top one is capped off and the solenoid valve is connected directly to the vacuum manifold on the rear of the engine. Either way works fine.
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #6 (permalink)
Old 05-11-2008, 04:09 PM
nicoblue is starting off with a positive reputation.
Talking pcv lines
Hey rough running 3.0...found a hose off and tell it has been plugged onto somethin but cant find where?it comes from pcv and ends under air filter housing.cant see anything to connect it on in or around air filter?Please help, any idea where it connects?I see the vac diagram posted but cant make since of it.
  #7 (permalink)
Old 05-11-2008, 05:34 PM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
carbon cannister fuel vapor purge recovery system under aid cleaner box.
2 bolts in bottom of air box to remove
vac. valve on cannister
  #8 (permalink)
Old 05-11-2008, 06:53 PM
thanks!
I appreciate it i actually found it during the time you posted.
sprayed sensor cleaner on maf an in throttle boby and ccrv and wiped out...
replaced hose from ccrv to the canister you mentioned Whiich looked like it had been off for awhile, cranked it up and it ran for about 5 min conked out and now wont run at all...lol figures!in my attempt to fix rough idle and muffled acceleration I have render inoperative!!!
  #9 (permalink)
Old 05-13-2008, 08:06 PM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Did you leave off the MAF sensor wire ? or any other connector.... although you should be able to leave it off & engine still runs. Check your gas tank!
Touch wood; I've never had that problem yet!
Aeroman
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
  #10 (permalink)
Old 05-14-2008, 01:24 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Its also possible that the MAF sensor was damaged when you tried to clean it. Try unplugging it to see if that doesn't help a little.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
