6.0 transmission cooler
I just purchsed a 6.0 cooler for my '01 F250 7.3 PSD. Before tearing into the grill, and assorted coolers, I want to be sure I have all needed parts on hand. This is where I need some help. Are there supposed to be rubber pads or other vibration absorbing mounting device on the tranny cooler brackets? Or do they simply bolt up metal to metal?
From reading past posts I know several on this forum have made the same swap and I'm counting on your expertise.
The bottom two bolts can be a mess to get in. Use a long extension and go through the front beside the fog lights if you have them. You will need a larger washer than the 7.3 OEM bolts have on them. You will need 3/8 to 1/2 adapters.
The 6.0 intercooler barbed connections are for 1/2 inch hose. The 7.3 is all 3/8 inch hose. Just get a few feet of hydraulic hose and two 3/8 to 1/2 adapters to go from the factory hoses to the cooler and back.
Also, I drained the radiator and took out the radiator and intercooler. Gave me plenty of room to work and an opportunity to clean and flush everything while I was changing out the tranny coolers. Good luck.
It was a good 5 hrs to do mine. Like the guys said just some adapters and 1/2" hose is all you need.. I got my adapters at Lowes and the hose at oreillys. Carefull on how you run the hoses,,Chaffing could be an issue where they go thru between the radiator and the intercooler. I have been watching mine closely. I ran the 1/2" hoses out and under the radiator before i adapted them to the 3/8 hose.Time consuming and hard on the hands but very doable and your tranny will thank you, BIG TIME.!
Its has been around 96 degrees ambient for the past couple of days and my trans temp does not quite get to 150 with mixed driving (interstate and city) empty. Is that around-about what you guys are getting with your 6.0 cooler? Normally with my stock cooler I was seeing 165 with the same mixed driving.
On a side note, BTS said they weren't sponsors of this site and I mentioned that this is where I heard of them. Brian said he would be interested in being a sponsor. I was pleasantly surprised to see that they are now sponsors.
Originally Posted by Kwikkordead
Nice work!
I had the plastic piece between the bumper and radiator mount, and the license plate bracket off and have no fog lights. Unbolted from underneath and slid new one in from bottom by loosing the lower condensor brackets, and p/s cooler. I was able to leave the grill, radiator and intercooler all installed.
Originally Posted by aklim
Thanx. I just mentioned to him that we heard of him on this board. He said he never heard of this board. He said he would like to be a sponsor if we could give him some info. All I did was to request info in his name. Not a biggie. The way I see it, it is a win-win situation. The more people hear about him, the more they will want his products. The longer he stays in business the better it is for all. Getting him here was a no-brainer.
Originally Posted by jtharvey
Nice work. I've mentioned this forum to Brian before (on a couple different occasions), but I didn't know we could request to have info sent to him. Nice to see that they are now sponsors!!
Warren
