What compression ratio are ALKY and NITRO (TOP FUEL) engines built to?
Yeah, but with the stuffer factored in - what IS the pressure in there?
Last word I remember was 8:1 with 10PSI from the blower for ALKY.
I don't know anything at all about nitro fuel.
On ALKY - it stands to reason that 15psi (sea level) plus 10 = 25.
25 X 8 = 200PSI
Sound real?
25 X 8 = 200PSI
Sound real?
Here is some good reading. Compression ratio is around 6.5:1
http://www.answers.com/topic/top-fuel
http://www.hondaprelude.to/forums/sh...ad.php?t=63701
Stryder
Stryder
3.8 to 4.5 bar = 3.8 to 4.5 X 15PSI
Scuse me a moment....
67.5PSI from the blower
times, umm...
6.5?
438.75 PSI compression.
Is this right? Does it look that way to you?
4.5 X 15PSI X 6.5 = 438.75
3.8 bar X 6.5 = 370 and change....
Around 400 psi, roughly.....
430 divided by 15PSI is about 28 2/3 to one compression....
(Sloppy math, I know)
300PSI is about normal for diesels.
times, umm...
6.5?
Originally Posted by stryder
Not quite, but close.
1 bar = 14.5037738 pounds per square inch.
So 4.5 Bar = 65.2669821.
65.2669821 x 6.5 = about 424.24psi
Stryder
Edit: Just realized I part the 500 post mark. Cool
That only took 6 yrs.
Stryder
So, it's in the ballpark, and obviously if you wanted to run either-or you would want to "BELT UP" or "BELT DOWN" the blower drive using pulleys...
ARAGORN! You just made my whole day. I'm considering building something SEISMIC...
I would believe it. Those top fuel thingys produce so much horse power that it is basically immeasurable by a mechanical device and can only be estimated. They are producing 4000+ HP at what, 8000 RPM, not much trouble for a big blower like that to produce 65 PSI; I'm sure there's plenty of reduction gearing in the blower drive gearing to make them spin unbelieveably fast.
Well - you figure top fuel has all been about the really gigantenourmous engines so far, but a V6 just might could be built for a smaller chassis.
If it was to a top fuel build ideation it might could kick some serious backside....
And then there is FOUR WHEEL DRIVE to spread out some of the horsepower!
I don't prezactly know yet, I'm still kicking ideas back and forth.
- But YES it will be a Ranger II truck.....
Actually, most RC engines run on a Nitro mix, and they are pretty small. I havent found an Octane rating for Nitro yet, but I can tell you it can be VERY explosive in the right conditions. Especially 100% pure. Dont quote me on this, but I can remeber somewhere that you some dirt track/ and drag racers run a small % of nitro in their fuel. I think its under 10%. Not completely sure though. I'll keep digging and keep ya posted.
Stryder
Stryder
