efi 331 stroker - Ford Truck Enthusiasts Forums
efi 331 stroker
Old 09-01-2006, 07:08 PM
bbjohnson bbjohnson is offline
bbjohnson is starting off with a positive reputation.
efi 331 stroker
Hey, I'm wondering if someone can tell me if I can replace the intank pump with a high pressure pump and bypass the frame mounted pump. I want to put the Mustang setup in and would like to reach 400hp. If this is possible what size pump would I need?
Thanks for the help.
quick pump swap Q. Greg5OH Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-18-2012 07:28 AM
1990 F250 dual fuel tank fuel flow toycraftusa 1987 - 1996 F150 & Larger F-Series Trucks 1 02-03-2008 01:40 AM
Need a new fuel pump!!! dwrestle 1987 - 1996 F150 & Larger F-Series Trucks 4 04-03-2006 09:07 AM
holley fuel pump leaking oil? ranger429 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 09-09-2003 06:06 PM
Fuel pump knocking noise? Wrong type arm? ADSf100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 18 05-02-2003 09:43 PM
Tags
150, 331, 86, efi, f150, ford, motor, stroker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
