86 f150 runs great till it gets hot
<HR style="COLOR: #666666" SIZE=1> <!-- / icon and title --><!-- message -->
my [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]truck[/font][/font] runs great untill it warms up then it spits & sputters when driveing it i replaced the following parts,tfi-1v [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]ignition [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]coil[/font][/font],tfi-1v ignition [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]control [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]module[/font][/font],water pump,thermostat, temperature sending unit i checked the iat sensor ( air charge [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]temperature [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]sensor[/font][/font]) or (intake air temperature sensor) it says it is ok i also replaced the low & high pressure fuel pumps & filters the truck is stronger & faster running then ever untill it gets hot the temp guage is working fine if anybody can help it is very needed i am about to give up & send it to the scrap man i hope it is just something i am overlooking thanks in advance for your time & input it is [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]fuel [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]injected[/font][/font]
my 86 f150 efi auto 4x4 runs great untill it gets hot then it looses power spits & sputters the parts i replaced are fuel pump high & low &fuel filters,water pump,thermostat,temperature sending unit,tfi-1v ignition control module,tfi-1v ignition coil,i checked the (iat) intake air temperature sensor also called (act )air charge temp sensor it read good both test cold then hot it runs great idles fine it has more power then ever when driveing till it gets hot then the sputtering & power loss starts it still idles fine wile acting up hit the gas & blaaahh i hope this is the rite way to do this message i really need the help maybe you can e-mail me if it is not
thanks in advance for the help & your time
goofy69 wayne
goofy69 wayne
Hey goofy69, I have the same issue too. Truck runs fine cold, but when it reaches operating temp, is starts to bog on accelaration, backfire thur the intake and it dies. Stop and go driving kills the truck. It does not want to start. So I must wait for about an hour, then the truck will start. I replaced plugs, wires, ignition module, cap, rotor, coil, fuel filter. Checked all connectors, tested sensors, all TOK (test OK). A friend of asked me, when I removed the old plugs, some were they "wet". And I do remember a few of those plugs were wet. He suggest that I might have some failing fuel injectors. He saying run some injector cleaner (SeaFoam) and see what happens. If I don't see any improvements, I will replace the injectors. Question to forum members, Can I use the injectors off a mid to late 90's 5.0 motor with EFI? Plug and play?
