Keeping Overhead Console Bright...help!
So, I took out the wire that went to the overhead console display, but I still want to fix the radio one. Couldn't tell from this description where the wire was that I needed to remove from the plug (if the plug was behind the same kick panel as the one for the overhead display or behind the radio). Could someone explain? Thanks.
Remove the radio and it is the same color code as the wire you disconnected for the overhead display. Disconnect it, reinsert the plug into radio and you should be in business.
Something in the internal wiring of the radio is the cause of that, so I plugged it back in.
Update: I found Billgart is no longer on the Web, so I had to use the Wayback Machine to find the information. I will use this thread to replace the link in the 6.0L Tech Folder.
Always Bright Overhead Console
This modification is to simply keep the overhead console readout from dimming when the headlights or parking lights are turned on. All that is necessary is to disconnect this wire at the passenger's side kick panel.
Glad to find this thread
However my console display would periodically not show anything. And now for a couple years hasn't worked. I haven't "poked" around in the panels yet but these are clues to the puzzle. Anyone else have a problem with their overhead display not working that found the solution?
Welcome to FTE!
Will this work for the radio also? my truck (E99) does not have the over head thing (not sure if I would really want to put it in either), but I hate that the radio is so dim during the day its impossible to read it with out turning off the lights and I enjoy having the lights on (safety thing) so HELP!!! need the super smart folks to assist here! I am half tempted to put a switch in line with the radio to have a "day/night" type set up that I can flip on and off as I need to...also if you guys have pictures that would be nice too!
#29
#30
Received 3,090 Likes
on
