Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #46 (permalink)
Old 03-24-2008, 04:09 PM
scnname is starting off with a positive reputation.
I'm getting 16 around town...
  #47 (permalink)
Old 03-24-2008, 05:26 PM
bremen242's Avatar
bremen242 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BII Plow Truck
No this is incorrect. Follow the vehicle manufacture's label, period. Tire pressure is very critical. They don't spend the money to place a label there for nothing. The government does not 'Require' a tire pressure label unless the suspension was designed with a different pressure specification then the tire maximum pressure rating.
The PSI on the side of a tire is just the MAXIMUM pressure, so the tire mounting tech doesn't overinflate to seat the beads, and so the maximum weight of the tire has a reference point.
Underinflated or overinflated, it doesn't matter....the point is that it's wrong either way.
It's just like overfilling your crankcase by an extra quart of oil, you just don't do it.
Do not risk it, it's an accident waiting to happen with improperly inflated tires. I've know too many people who have skidded off the road due to overinflated tires too hard to grip the road, and many people underinflate and the tire tucks under the rim causing the vehicle to flip in a manuever.
We don't know more than the manufacturer's engineers, there are reasons they design the suspensions this way.
Hardly. The maximum pressure on the sidewall is the pressure for the maximum load carrying capability.
I don't recommend running a tire at the maximum pressure unless you are going to be loading the tires to close to their maximum weight rating.
With that said, I run 34lbs of air in my truck and my escape.
Perhaps Ford has engineered the optimum pressure for the tires that come from the factory; however, most of my vehicles are on their second or third set of tires, and I think the tire manufacturer knows more about their tires than Ford does.
__________________
http://mav.wastegate.net
'00 in the drive, '85 F250 that runs, '84 F150 in the weeds, minus 1 '85 F150- I finally got rid of some junk..
  #48 (permalink)
Old 04-26-2008, 07:40 PM
Viking2005's Avatar
Viking2005 is starting off with a positive reputation.
Ok. Comment on tire pressures. I have had one of every gen Explorer. Ford speced out a low tire pressure rating for ride quality (the sub 30 PSI rating in gen 1 Explorers and early gen 2). I have always folled the rule of thumb to use 3-4 PSI less then the manufacturers rating on the tire (does not apply to high performance low profile tires) for the 20 years I have been driving and I have never ever had a blow out and all my vehicle tires have lasted above the manufacturers life rating on the tire. All three gen Explorers have had either Perielli Scorpion or Michelen tires that lasted between 60-70,000 miles before I even came close to the wear marker on the tire. I achieved on average 23-24 MPG highway with all 3 gens (all 4x4, OHV V6, SOHC V6, SOHC V8). I even ran tire inflation tests on my gen 2 Explorer to see how much the PSI affected MPG. I noticed a 2-4 MPG differance. My current Explorer is a 05 XLT Sport with a V8, and I have the tires inflated to 38-40 PSI. When i recieved the Explorer from Ford, the tires were set at 30 PSI. I averaged 18 MPG. After I raised the tire pressure to 40 PSI, I was averaging 21-23 MPG, all other things being equal. As stated before the tire manufacturers are the experts on the tire, the auto manufacturer knows the vehicle. a change of 5-8 PSI will not affect the vehicle under "NORMAL" driving conditions, that is not driving a SUV at 90 miles an hour or such. People forget a SUV is not a car, it is a truck, and therfore with a higher center of gravity can not be driven like a car without expecting something to go wrong. If you are responsible and know the limits of your vehicle you will not have an issue. But today people are so into placing blame on others. If you are buying a vehicle you are the owner and responsible for its upkeep and driving it. If you take care of the vehicle, it will take care of you with being reliable and safe.
  #49 (permalink)
Old 05-08-2008, 08:01 PM
bf250's Avatar
bf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to beholdbf250 is a splendid one to behold
i guess the world will end when someone puts on new tires that are different then the stockers....what then? can't go by the cute little label on the door.
and yes, engineers know best, thats why they have some great designed products like e4od transmissions, explorer trans, those great ball joints on the superduties (couldn't leave well enough alone) and probably 1 million other little profit making schemes.
__________________
current ride - 2003 explorer, 4x4, v8
ford trucks i have previously owned
1972 f250 1989 f250
1995 f350 2004 f250
2006 f250
will get a truck again!
  #50 (permalink)
Old 05-09-2008, 11:19 AM
goingnorth is starting off with a positive reputation.
"and yes, engineers know best, thats why they have some great designed products like e4od transmissions, explorer trans, those great ball joints on the superduties (couldn't leave well enough alone) and probably 1 million other little profit making schemes"
Hey I've had each one of those problems, many times each!! Thanks for reminding me, always breaks just out of WAR..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
