were is the DPFE
were is the DPFE
Hi, new to the site, and I have read several of the threads about the DPFE. I have a 2001 F150 4x4 with the 4.6 engine and 77k miles. I have a service eng soon code of 401 and 402. One fix on this site is to replace the DPFE, but I can't find it. My EGR valve has one vac line (green) that goes to the SOL V. and from the SOL V is a (red) vac line that goes to the intake. The SOL V also has an electrical connection . The hood decal of the vac system calls it SOL V (EGR). I bought a DPFE from Ford and it is like everyone describes it 1 elec connection and 2 vac ports. It looks entirely different from the SOL V that my EGR connects to. Does my truck even have a DPFE or did Ford give me the wrong part? Sorry to be so long winded, but more info is better than not enough. Any suggestions?
thanks
Fordhonda
thanks
Fordhonda
Originally Posted by mneal
Are you sure the DPFE is bad? clogged EGR ports in the TB is very common and will throw same code. Cleaning the ports is free so you might want to check that 1st.
A clogged port CANNOT cause cause excessive flow - think about it.
DPFE sensor is the correct diagnosis.
Steve
artfd
1997 - 2003 F150
50
11-29-2017 06:37 PM
UZI-SUICIDE
115
08-05-2013 08:00 AM
moorefc
12-31-2008 05:49 PM
