Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-30-2006, 05:42 AM
ford5t6 ford5t6 is offline
Garage is empty, add now
ford5t6 is starting off with a positive reputation.
flathead 6 in a 51 f1 or drop in a v8?
hey guy's,
i'm looking to buy a project '51.
it has the original flathead 6. (4.2 liters is this possible?)
is the 6 a dependable engine?
i'm thinkin to swap it for a v8 flathead
i want to do a rat rod.
like to know if the 6 is strong enough or if you can tune it to make it faster.
it has the manual gearbox
thank you
twan
  #2 (permalink)
Old 08-30-2006, 09:48 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Quote:
Originally Posted by ford5t6
hey guy's,
thank you
twan
4.2 is possible if its the 254 used in the larger trucks. Check the block or head for pn using 8MTH as a prefix. If it's the smaller 226 (3.75ci) the pn's will prefix with 7HA.
6's are very dependable, smoother running than 4's or 8 due to the longer crank. Bore size for the 254 is 3.5" and stroke is 4.4" so they're natural torque engines - they are not high rpm engines. The engines are strong, but tuning won't make it much 'faster'. There is not much speed equipment that has ever been made for these engines.
Like modern drivelines, you can overcome the speed limitations with taller gears in the differential (a 9" rear from any 57-72 F100 will bolt right in) and use a modern OD transmission like the S-10 T5.
I think they are great in hotrods just because they are unique. 'Course the flathead V8 is sweet also. Your choice - have fun!
  #3 (permalink)
Old 09-01-2006, 06:43 PM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
It depends on what you like. I've heard that 6 referred to as Henry's best kept secret.
A friend of mine had a bachelor Norwegian uncle in northern Minnesota who always drove Ford sixes, because he had to purchase two fewer sparkplugs for a tune-up. Now, that's frugal.
If that is a good running 6, I'd stick with it.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
  #4 (permalink)
Old 11-17-2006, 11:03 AM
TallPaul's Avatar
TallPaul TallPaul is offline
2001 Ford Ranger
TallPaul is gaining momentum as a positive member of FTE.
I heard when Ford first came out with the flathead six it was more powerful than his flathead V8 and so they had to de tune it a bit. But for raw get out and go, the v8 probably will do better as it can be run to higher rpms and will have more speed equipment available. Still, if it were me I'd take the six.
__________________
'01 Ranger, 2.3L, 5 speed, 83,000 miles. Redline MTL, Amsoil Signature 5w20, Wix Oil Filter, Dynomax Super Turbo muffler.
  #5 (permalink)
Old 11-17-2006, 12:58 PM
ksmith203's Avatar
ksmith203 ksmith203 is offline
ksmith203 is gaining momentum as a positive member of FTE.
I am rebuilding a flathead 6 226. I bought the deluxe rebuild kit from kanter. I was told by Story motors, who rebuilds flathead, that he has had to junk fewer 226 or 254 due to cracked blocks. After I tore apart two flathead 8's and both had numerous cracks, I finally agreed. I tore down the 226 and block was good. I ordered kit and engine will be bored .030 over by next week. Story is going to let me assemble it right in his shop. He doesn't want me to screw it up. Nice to be in small town. This is just what I'm doing, an original as possible rebuild of a 51 F6. Next I will start a 51 cabover.
Good luck with your project.
Kevin
  #6 (permalink)
Old 11-28-2006, 04:04 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
My 51F1 had has the 226, it had been sitting for 17 years prior to my purchase the 226 was not froze up when I purchased it. The PO had started converting it to 12V and gave up 1/2 way through. The engine had no compression due to the valves being stuck open, I poured in Marvel Mistery Oil and left it sit for a week. I then added more, after the second week I was able to get it started. I really ran rough but I managed to drive the truck 28 miles home. That was 3 years ago and the 226 is still running good for not having been apart sense 1971. The only problem I see with them is if you plan to venture out on any long trips and you have a breakdown you could be sitting for awhile trying to find parts. Especially if you loose the gear that turns the distributor/oil pump off the cam, they can be real tough to find. The early 7HA and the later OHA model are both different, also the cams are different (from what I understand). There was a guy in Europe here awhile back trying to track one down, he did finally find one. The V8 Flathead is the one I tend to lean more toward because of the availability of parts is so much better. But if you really want whichever Flathead you choose to rock put an S-10 5 speed trans behind it, it's a perfect match. JMO
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #7 (permalink)
Old 12-22-2006, 03:26 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
I have to dissagree about the six being a smoother running engine than the eight. I cannot imagine it running smoother than my V8. As smooth maybe but smoother I just don't know. My truck runs smoother than anything else I have driven, including anything new.
Tags
226, 254, 7ha, engine, equipment, f1, flathead, ford, motor, speed, swap, tuning, turbo, v8, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
