Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-29-2006, 08:14 PM
HHjr HHjr is offline
HHjr is starting off with a positive reputation.
EGR/DPFE Success story
Thought I'd post my story .... thanks to the great folks/advice on this forum I got my 1998 5.4 Triton E150 ClubWagon running SMooooth again.
Had the PO401 code and a very ratty running van, at the time did not have a vacuum tester and removed the EGR valve to expect the port clogged. The port into the throtle body was remakably clean. I have 125K on "The Beast"
A couple days later borrowed a vacuum gage and tested the EGR .... the motor fell on it's face with the first squeeze. Tonight I replaced the DPFE with a Ford part as recommended here .... was $87 w/ tx here in central lower MI. Took about 20 minutes to R/R it and she runs great. I am sure the ports will glog in a few more K .......Thankyou all very much.
Harold H.
  #2 (permalink)
Old 09-12-2006, 10:29 AM
cranker cranker is offline
cranker is starting off with a positive reputation.
I got a '93 E150 conversion van with 140,000 miles on it a couple years ago. Before I became familiar with anything under the hood, it died and had to be towed to a garage, where they checked it with their computer. Their diagnosis was a bad vacuum part that ended up costing me $300. A few months later it died again on the highway. I puuled the engine cover off and started checking any hose that looked like a vacumm hose. I found one that had begun to deteriorate and was not maintaining a tight fit. With a pocket knife, I trimmed off the end and reinstalled the hose, which seemed to solve the problem. This happened two more times. I decided to carry spare vacuum hose and have now replaced the worst of them. The engine runs like new and has been reliable for at least 20,000 miles.
Tags
54 , clean , clubwagon , dpfe , egr , engine , ford , hoses , ports , sensor , symptoms , triton , tube , valve , van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
