Overheating 1990 7.3
Received 3,102 Likes
on
on
1 Post
Did you clean the little ball check valve next to the thermostat in the thermostat housing? If it is fouled then you could be getting vapour lock as it is there to relieve any steam, vapour, air to the radiator.
Are you still running the 1990 radiator. If so it probably is getting pretty plugged up and need a new core.
Best of luck,
Seb....
Best of luck,
Seb....
on
I had the same problem with my 1992. I changed everything fanclutch radiator thermostate still would run hot under a load or in the hills it turned out to be that little ball in the check valve. that is in the termostate housing. I replaced the the housing and the problem whent away. you can get the themostat housing from rockauto.com for under $30 and a ford factory thermostat from the same place for under $25. delivard.
SirPluto
05-27-2012 02:35 PM
RenoJohn
07-25-2011 10:21 PM
