Tires
I would recommend against this change, but you could probably get away with it if necessary. The load capacity is less, so be sure you aren't overloading them, and they will probably wear faster and handle worse. Also, the rolling diameter is less, so your speedo/odometer will read differently, and this might affect shift points, etc. Lastly, IMHO, it will look funny; these trucks usually look better with larger tires.
Originally Posted by 02Ford150
What is the biggest 16in tire available?
And also a 44x21x16
I have 285/75/16's on my truck (4x4). Comes out to 33x11.50x16
The 265's you have are actually 32" tires...and look good on these trucks. Thats what my truck had when I bought it.
FYI: 2001 F150 4x2 XLT Sport. My snow tires are 265/75R16. Stock wheels/tires are 275/60R17. I believe similar 4x4's came with 265/70R17's ('70' Not '75'). The snow tires are noticeably larger in diameter, and definitely affect driving characteristics; less acceleration, and dry cornering ability; but better slippery condition traction for winter.
PS: Check out the tirerack website to see the comparative revolutions per mile for various sizes. This will indicate the change in effective final gear ratio for your tires.
