Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-29-2006, 01:30 PM
willyswrecking willyswrecking is offline
Garage is empty, add now
willyswrecking is starting off with a positive reputation.
What oil??
I am getting ready to fire up my 49 F2 for the first time since 1972. I am going to change the oil, but I'm wondering. Should I be using 20w non-detergent? Also, is there a way to increase the flow through the filter?? I understand the filter is next to useless the way it is now.
  #2 (permalink)
Old 08-29-2006, 06:00 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
If the engine has not been disassembled since 1972 and is likely very dirty inside, I'd use non-detergent oil. A lot of loose dirt or sludge can break loose, plug your pump screen and wipe out the bearings in short order. If the engine has been apart and is fairly clean then just run regular 10W-30. These old motors aren't too awfully picky.
30W is what the operator's manual calls for. Extreme cold of winter use 10W.
I just run 10W-30 or 10W-40 year round.
The filter system is minimal, but there is no good way to increase the flow (flow and pressure are opposites). You can go to the expense of installing a full-flow system OR use the stock system and just change your oil regularly. The stock setup filters approx 10-15% of the oil at any one cycle - eventually it all gets cleaned.
  #3 (permalink)
Old 08-30-2006, 08:04 AM
I don't believe the engine has ever been apart, so I guess I'm going with the straight weight then. Thanks.
  #4 (permalink)
Old 08-30-2006, 08:25 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
since your ford is a truck and if it has a V8 there should be a clean out panel on your oil pan. Its very easy to take on and off and is there for the sole purpose of cleaning out the pick up screen on the oil pump without dropping the oil pan. I would deffinitly pull the plug and check the screen for any blockage before start up. If its clean I would run detergent oil. Personally I run rotella 15w40 in my 51 F-6 with a V8. I had to pull my intake off after dropping a brass feral nut down my intake while changing my carb out@#$&!!!! The inside of the motor was spotless so I used detergent oil and have not experienced any problems. I kept a close eye on my oil pressure and changed my oil the first couple of times in close intravells to make sure everything was OK.
  #5 (permalink)
Old 09-01-2006, 06:38 PM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
F6Guy:
How do you clean the screen? Does it come out through the large opening in the pan bottom?
I've been running 10W-30 in my flathead; seems to like it.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
  #6 (permalink)
Old 09-03-2006, 08:31 AM
hey Stev8e hows it going. When you unbolt that panel you will be looking at the bottom of the pickup screen. There should be a spring clip holding the screen in place remove the clip and the screen will come out.
  #7 (permalink)
Old 09-04-2006, 12:51 PM
Mine is a 6, so I just have a plug in the bottom. I drained the oil, and it looked thin and fairly clean. I just put 30W in.
Tags
1952, flathead, flow, ford, oil, plug, system, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
