What caused the DPFE sensor to melt? - Ford Truck Enthusiasts Forums
Old 08-29-2006, 01:02 PM
tmm66 tmm66 is offline
tmm66 is starting off with a positive reputation.
I have a '99 EX with the 6 cyl OHV motor. I found the HIGH port on the dpfe sensor was melted and the hose that connected to it was severely cracked. I replaced the sensor and hose but would like to know the root cause of the problem. Any suggestions?
Old 08-30-2006, 09:08 AM
renchr56 renchr56 is offline
renchr56 is starting off with a positive reputation.
The exhaust tube may be plugged with carbon. you will have to pull it & find out.
Old 08-31-2006, 12:56 PM
I'll try it hopefully this weekend. If this tube was clogged, wouldn't this cause the "check engine" light to come on? Just wondering...
Old 08-31-2006, 01:39 PM
depends on if it is clogged all the way or not
Old 09-05-2006, 02:56 PM
The tube was not clogged at all. The hose from the HIGH port did show signs of carbon buildup. We'll keep an eye on it.
thanks,
Old 09-06-2006, 12:31 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
the sensor it self shorts out and over heats. seen a few of these. atleast you did not have to replace your intake
Old 08-12-2012, 03:42 PM
George M Baxter George M Baxter is offline
George M Baxter is starting off with a positive reputation.
Sorry your all wrong!
In normal operation there is no gasses traveling through the tubes. This device measures deferential of pressure. But as you stated the hose had cracks (leaks) This aloud the hot gasses from the Exhaust to flow through the hose to the DPFE sensor melting it. A clogged line would not melt the sensor but would make it inoperable.
Old 08-12-2012, 04:05 PM
More info
Witten by wildbill a person that worked for the company that designed and manufactured the sensor for Ford Motor Corporation.
Exhaust stream does not pass through this transducer(DPFE) the pressure applied to the sensor is a dead head so the thermal transfer is contained to the stagnant air trapped in the hoses to the sensor that is very slow to transfer heat.
The plastic housing was to reduce cost of this transducer(DPFE) not to dissipate heat in fact the plastic transducer would melt with pressure leaks.
Update dpfe burnt manifold jetfiremuck Aerostar 0 12-18-2016 12:28 AM
Dpfe sensor burnt hole in manifold wtf jetfiremuck Aerostar 3 12-07-2016 09:41 PM
99 Ranger 2.5L P1401... Replaced DPFE 207peas Ranger & B-Series 2 04-27-2015 09:27 PM
melted dpfe sensor carlakally New Member Introductions 1 04-23-2013 04:19 PM
replaced melted DPFE-- now I get a P0401 code piedmont Explorer, Sport Trac, Mountaineer & Aviator 2 08-16-2007 11:07 AM
Tags
2000, clogged, dpfe, egr, explorer, ford, hose, melt, melted, melting, melts, senor, senso, sensor, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
