3.0L V6 Identification
Is there some sort of 3.0L V6 identification guide? My son's 96 Ranger had an engine replaced but I wasn't able to find out what the donor engine was from. Would the engine serial number have that encoded? Where do I find the serial number? If I post a few pics of the engine, can you guys maybe narrow it down? I need an idler pulley for it but I can't just ask for an idler pulley for a 96 Ranger anymore.
Thanks.
Thanks.
Good point.
FWIW, there is supposed to be a "Ford Broadcast Code" sticker that is used by engine rebuilders to determine the exact engine and application ID. It is a paper sticker usually located on the cam/rocker/valve cover and/or the front cover. The stickers are often marred up real good or gone completely, but it's worth a look.
If you get the code you might be able to call a dealer or rebuild shop and have them tell you what application the code points to.
mnewbolds
03-12-2016 10:59 AM
dclarkson
1983 - 2012 Ranger & B-Series
12-24-2011 08:20 PM
