Changing 1990/4.9 oil pan gasket - Ford Truck Enthusiasts Forums
Old 08-28-2006, 05:10 PM
mundt mundt is offline
mundt is starting off with a positive reputation.
Any ideas on how much time it would take, without access to a hoist? Any particular things to watch for, and do you have to be careful about overtightening the bolts? Any particular sequence in tightening the bolts?
Old 08-30-2006, 12:17 PM
papaw123 papaw123 is offline
papaw123 is starting off with a positive reputation.
I have a 1991 F150 4x4. I unbolted the motor mounts, placed a wooden block against the crank pulley and used a bottle jack to lift the front of the motor. I had to remove the windshield wiper motor to get enough clearance because the back of the intake touched the motor. You can then remove the bolts and slide the pan out the back. In replacing the gasket, I did not use any specific sequence but make sure you don't overtighten the bolts. One thing I wish I had done last time... Replace the oil pump whether you think it needs or not. I didn't and now I need to do it again.
Old 08-31-2006, 08:27 PM
FordCwazyGuy FordCwazyGuy is offline
FordCwazyGuy is starting off with a positive reputation.
i just did mine thinking it was the oil pan gasket but found out it is actualy the rear seal leaking into the front side of the tranny/engine plate by the back of the oil pan..just unbolt the motor mounts,jack it up..put blocks under the motor mounts..do it from there like was said..slide it out the back..i put a high volume oil pump in mine while i was in there..this engine has over 250k on it & still running strong..even ran for a few months with a cracked because of an overheating incident..put a new head on it & pulls like crazy.
Old 01-15-2015, 01:54 AM
SkiBikeClimb SkiBikeClimb is offline
SkiBikeClimb is starting off with a positive reputation.
I just replaced my 1990's 4.9 oil pan gasket with a Fel Pro and it took me about 5 hours without lifting the engine. I am an intermediate mechanic but pretty straight forward. Drain the oil, drop the pan, and shimmy the new one in. It can absolutely be done without hoisting the engine though, confirmed.
Old 01-15-2015, 11:55 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Just fwi, the previous message was 8 years ago. Always a good idea to check the post date before replying (unless you're asking a new question on old information). Otherwise it just clutters up the front page.
But yes, I've done it without a hoist (a lot easier with one) by using the same method of a block of wood on the front pulley. Unbolting the transmission and exhaust helps too.
Put ALL the bolts in before doing any tightening, and then start from the center and move out toward the ends. Never overtighten, even if it doesn't feel snug enough, or you'll crush the gasket and you'll have to start all over.
One of my least favorite jobs on the engine.
Old 01-22-2015, 05:42 PM
phroldschool phroldschool is offline
phroldschool is starting off with a positive reputation.
took me 2 days
Changed the gasket in my gravel driveway. Had a hangup when my engine got off balance on myblock of wood and jack. Had to wait for a neighbor to come home and muscle it back on the motor mounts correctly. No fun at all. It wasn't 3 months and my rear main seal went out. Going ttj
IS there a less "whinie" style PS pump out there? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 10-24-2014 07:12 AM
Removing Injector MC333 1994.5 - 1997 7.3L Power Stroke Diesel 50 04-29-2012 03:37 PM
ECM identification TexasRebel 1999 to 2016 Super Duty 0 09-06-2010 06:00 PM
Oil Pan Bolt Pattern? berry1234 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-06-2009 02:09 PM
cold air intake mudlite 2004 - 2008 F150 24 09-20-2008 08:19 PM
Tags
1990, 300, 49, 49l, bolt, changing, e350, f150, ford, gasket, oil, pan, replace, sequence, tightening
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
