Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 08-30-2006, 07:29 PM
Purdue Offroader's Avatar
Purdue Offroader Purdue Offroader is offline
Purdue Offroader is starting off with a positive reputation.
thats amazing, I just built one of these for my jeep and truck and then I come on here and it was in the recent reply thing on the front page, heres how I did mine http://www.bmw-m.net/TechProc/bleeder.htm cost 25-30 bucks, still waiting for RTV to dry so I can't tell how it works right now but it should be good
__________________
'79 F-150 351M.... Check out PORC.Purdue.Org Purdue Offroad Club
  #17 (permalink)
Old 08-30-2006, 07:48 PM
rmilchman rmilchman is offline
rmilchman is starting off with a positive reputation.
By this time I would think if they were not broken inproperly, they must be due to time.
__________________
2002 F-350 4X4 CC PSD. straight pipe, k&n air box, tuner, 203 thermostat, mag-hytek tranny pan, tranny springs and valve, ranchhand bumper, air horns
  #18 (permalink)
Old 08-30-2006, 08:17 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
here is a question in relation to this brake bleeding deal, but off topic too. i bled my brakes the other week, and was surprised at the greenish-black gunk that came out. they had never been bled before as the bleeder screw on the LR caliper twisted right off at the flange of the caliper and the screw. it is just a flat surface now with a hole in the center. didn't even budge inside the caliper. do i need to get a new caliper or can i get that screw out somehow?
__________________
2002 F-350 with some mods, current best 12.8 @ 104 Fuel only
Spooled, Fueled, and Tuned by Swamps Diesel Performance, Trans by BTS, Engine built by me
Swamps gives me enough power to break a BTS
  #19 (permalink)
Old 08-30-2006, 08:23 PM
ssnh ssnh is offline
ssnh is starting off with a positive reputation.
Quote:
Originally Posted by HeatStroked
One man job once you get these installed...
http://www.speedbleeder.com/
i use russell speed bleeders on everyone of my vehicles.
http://www.russellperformance.com/au.../sb-ford.shtml
i buy them from summit
http://www.summitracing.com
  #20 (permalink)
Old 08-30-2006, 08:57 PM
jtharvey's Avatar
jtharvey jtharvey is offline
Lost Soul
jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all
Uhhh, Kris, you have a problem. I'd try some of the normal methods for extracting a broken screw. A little penetrating oil, let it sit. Use a screw extractor to try and back the thing out. Problem is, IIRC, the bleeder screw is a soft metal and the extractor will most likely just tear up the bleeer. Give a little heat to the caliper around the screw, but not the screw itself. Don't worry about the fluid in the caliper, since you can bleed it out later. But, don't get it too hot or you will burn/melt the rubber seals around the pistons.
I guess it's up to you to decide whether or not to try and get it out. I priced new calipers, witout pads, a couple days ago. The passenger side is sticking when hot - new slide pins last year, so that shouldn't be it. Wheel is hard to turn when jacked up. Most likely caused by the pistons not fully retracting caused by dirt around the seals, and the pad rubbing the rotor. Anyway, the new calipers from O'rielly' are under $40. Is it worth it to fight a stuck bleeder for $40? That's up to you.
__________________
Jeremy
See My Webshots for pics.
  #21 (permalink)
Old 08-30-2006, 09:03 PM
2002 Ford F-350
i would gladly pay forty dollars. i was planning on spending $250+ from the dealer. thanks for the info i guess i will try to extract the screw for fun but end up paying $35 for the new bleeder screw.
__________________
  #22 (permalink)
Old 08-30-2006, 09:23 PM
jtharvey's Avatar
Lost Soul
BTW, I'm pretty sure the calipers are remans, since they require a core, but that shouldn't matter. All they probably do is clean up the caliper, replace the seals, and possibly new pistons if needed. There's not much more to a caliper than that.
And, they want $250 for those things at the dealer?!?! I'd hope that at least includes new pads & new caliper brackets, in addition to the caliper itself.
__________________
Jeremy
  #23 (permalink)
Old 08-30-2006, 10:13 PM
2002 Ford F-350
no, i havent checked there yet. i was just guesstimating $250 just so i wouldn't be surprised when i actually found out how much they were.
__________________
  #24 (permalink)
Old 08-31-2006, 12:28 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is online now
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Kris as you get more experience with working on cars and trucks you will learn when to stop pushing against the wrench because that bolt (or bleeder) is going to break.
It's sort of an art more than a science.
Lot's of Free-All always helps.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #25 (permalink)
Old 10-04-2006, 11:59 AM
ALANSD's Avatar
ALANSD ALANSD is offline
ALANSD is starting off with a positive reputation.
I have had an issue with my rear brakes (97 250HD PSD 4x4)locking up sometimes. Last week while towing a 5000lb trailer the rear drivers sdie locked up and started smokin'.
I saw the TSB about the brakes locking due to handbrake cable problems, and moisture problems also. Anyone else fixed this on their own lately? Should I replace the shoes with organic? What is the deal on the brake cable? Thanks
  #26 (permalink)
Old 10-04-2006, 02:53 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is starting off with a positive reputation.
Stupid question here.
Do you need to pump the pedal or will the pressure push the new fluid out? Any concerns regarding the ABS pump? Any special precautions to take with the ABS pump?
How did you drain the MC first? Suck it out, or crack the lines and pump it out?
__________________
John
2008 F350, 6.4, Crew Cab, King Ranch, 4WD, SRW, 62,000 miles.
2001 F250, 7.3, Crew Cab, Lariat, 2WD. 329,000 miles and counting!!
  #27 (permalink)
Old 10-04-2006, 02:59 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel is gaining momentum as a positive member of FTE. Fat Diesel is gaining momentum as a positive member of FTE.
The pressure from the power bleeder will push the fluid out the bleeders at each wheel. I have ABS and didn't take any special precautions either time. You can drain the MC first if you have a mity vac or something with a small enough tube. Take the cap off and look and you'll see what I mean. Last time I did it by pushing it through the system. Make sure you push MOST of the fluid out of the MC and then add new fluid, you don't want it to go dry in there.
__________________
Andy
Early 99 F250 PSD 4x4 CC 6spd ----- CCV Mod, 6637 Filter, DP Tuner Chip, ITP Fuel Sys, Dahl Filter, Cat Delete, BD 4" Cat Back, 203* 230,000+ Miles
  #28 (permalink)
Old 10-04-2006, 03:10 PM
John7894's Avatar
OK, thanks. I planned to do a flush when I do the rotors/pads up front. This way seems very easy.
Did that pump come with different MC caps for different vehicles?
__________________
John
  #29 (permalink)
Old 10-04-2006, 03:17 PM
Fat Diesel's Avatar
It came with the cap for the PSD and some other Fords. You can buy different caps for different applications.
__________________
Andy
  #30 (permalink)
Old 02-14-2008, 07:07 PM
Gage2502 Gage2502 is offline
Gage2502 is starting off with a positive reputation.
Whats the model# for the Motive bleeder? They have different ones, I need one for my 2005 Superduty
Thanks ~Gage~
__________________
2005 Ford SuperDuty XLT SuperCab V10 4x4 FX4 Shortbed
2000 Ford Expedition XLT Sport 4x4 5.4L
Tags
2006 , a4 , audi , brack , brake , cost , duty , f150 , f250 , f350 , fluid , flush , focus , ford , super , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
