Engine swap
If the motor was from a 79 or older Ford truck, go back and get the frame-to-motor mounts and it should be a easy swap. It will need a new driveshaft, any good shop can help you here. Do alot of measuring around the steering box, make sure there is enough clearance, etc.. Good luck with your truck!
