1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Removing rear door panels on Supercab
Old 08-26-2006, 10:43 AM
bandaman's Avatar
bandaman
bandaman is offline
Ok guys, I need help please. I've been searching for hrs here and in the audio forum, but can't find anything. There are lots of threads about the front panels (got those off easy as pie) and the rears on crew cabs, but I need to know the tricks to removing the rear door panels on the Supercab. Truck is an 06. before I start yanking and breaking tabs off, I would appreciate some hints
Thanks for the help!!
Old 08-26-2006, 11:00 AM
bandaman's Avatar
bandaman
bandaman is offline
Nevermind, I figured it out....
Remove two phillips screws on window latch and fold it out of the way.
Pull the top half of the door panel straight out. I started on one corner and worked my way around, there are many tabs.
Once top half is removed it will expose two 7mm screws and two push-pin fastners.
Remove those and pull the door panel up and out.
Old 08-26-2006, 12:57 PM
crazyrwe's Avatar
crazyrwe
crazyrwe is offline
Thanks bandaman,I was wondering also. Al
Old 08-26-2006, 02:48 PM
supeRobertduty's Avatar
supeRobertduty
supeRobertduty is offline
Thanks ,I was wondering also
Old 08-26-2006, 07:48 PM
bandaman's Avatar
bandaman
bandaman is offline
Here are a few pics. THe top half requires a pretty good yank, don't be afraid to pull it, just use both hands and pull it straight towards you and the tabs will pop out.
Old 08-27-2006, 11:39 AM
crazyrwe's Avatar
crazyrwe
crazyrwe is offline
nice pictures,does that bottom arm rest come off with the whole panel?
Old 08-27-2006, 12:17 PM
bandaman's Avatar
bandaman
bandaman is offline
Yes, it is all one piece. Once you remove the two 7mm screws in the center and the two push-pin fastners on the edges, just lift up and out and the whole bottom section comes off easy. It takes about 2 minutes to remove the whole door panel.
Old 08-27-2006, 06:24 PM
crazyrwe's Avatar
crazyrwe
crazyrwe is offline
Great news and pictures,thanks. It will come in handy when I upgrade the speakers. Al
Old 02-14-2011, 05:49 PM
5.4L to Freedom's Avatar
5.4L to Freedom
5.4L to Freedom is offline
followed procedure as outlined, now need new door panel :/ and the tabs of the upper panel are still in the door, while the plastic is not attached.
Be careful with the removing of the top panel!!!!
motolorenzo
2004 - 2008 F150
03-07-2011 11:57 PM
Willy2000
2004 - 2008 F150
09-19-2006 05:42 PM
mikenutz
2004 - 2008 F150
09-28-2004 07:55 PM
WXboy
1983 - 2012 Ranger & B-Series
08-11-2004 01:08 PM
Supercab
08-11-2002 09:09 AM
Quick Reply: Removing rear door panels on Supercab
