Removing rear door panels on Supercab - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-26-2006, 11:43 AM
bandaman bandaman is offline
bandaman is starting off with a positive reputation.
Ok guys, I need help please. I've been searching for hrs here and in the audio forum, but can't find anything. There are lots of threads about the front panels (got those off easy as pie) and the rears on crew cabs, but I need to know the tricks to removing the rear door panels on the Supercab. Truck is an 06. before I start yanking and breaking tabs off, I would appreciate some hints
Thanks for the help!!
Old 08-26-2006, 12:00 PM
Nevermind, I figured it out....
Remove two phillips screws on window latch and fold it out of the way.
Pull the top half of the door panel straight out. I started on one corner and worked my way around, there are many tabs.
Once top half is removed it will expose two 7mm screws and two push-pin fastners.
Remove those and pull the door panel up and out.
Old 08-26-2006, 01:57 PM
crazyrwe's Avatar
crazyrwe crazyrwe is offline
crazyrwe is starting off with a positive reputation.
Thanks bandaman,I was wondering also. Al
Old 08-26-2006, 03:48 PM
supeRobertduty supeRobertduty is offline
supeRobertduty is starting off with a positive reputation.
Thanks ,I was wondering also
Old 08-26-2006, 08:48 PM
Here are a few pics. THe top half requires a pretty good yank, don't be afraid to pull it, just use both hands and pull it straight towards you and the tabs will pop out.
Old 08-27-2006, 12:39 PM
crazyrwe's Avatar
nice pictures,does that bottom arm rest come off with the whole panel?
Old 08-27-2006, 01:17 PM
Quote:
Yes, it is all one piece. Once you remove the two 7mm screws in the center and the two push-pin fastners on the edges, just lift up and out and the whole bottom section comes off easy. It takes about 2 minutes to remove the whole door panel.
Old 08-27-2006, 07:24 PM
crazyrwe's Avatar
Great news and pictures,thanks. It will come in handy when I upgrade the speakers. Al
Old 02-14-2011, 06:49 PM
5.4L to Freedom's Avatar
5.4L to Freedom 5.4L to Freedom is offline
5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.
followed procedure as outlined, now need new door panel :/ and the tabs of the upper panel are still in the door, while the plastic is not attached.
Be careful with the removing of the top panel!!!!
2004 SuperCab Rear door panel removal.... motolorenzo 2004 - 2008 F150 3 03-08-2011 12:57 AM
2004 F150 Rear Door Panel Removal Willy2000 2004 - 2008 F150 1 09-19-2006 06:42 PM
Stx Supercab Rear Windows!!!! Need Info mikenutz 2004 - 2008 F150 7 09-28-2004 08:55 PM
Removing rear door panels on 4-door Ranger WXboy Ranger & B-Series 3 08-11-2004 02:08 PM
'94 F150 Supercab Speakers Supercab 1987 - 1996 F150 & Larger F-Series Trucks 2 08-11-2002 10:09 AM
Tags
05, 2003, cab, door, doors, f150, f250, f350, panel, panels, rear, remove, removing, super, supercab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
