1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
I need you help PLEASE!!! Any input is great
Old 01-22-2011, 06:06 PM
Falcon78's Avatar
Falcon78
Falcon78 is offline
I have a 2002 5.4 Super Duty.
I was pulling a truck, on a trailer, up a hill today. As I was reaching the top of the hill I noticed all the gauges were not working and the truck seemed to lose some power. I pulled to the side of the road thinking something was really wrong. The truck was still running. I shut the vehicle off thinking I lost oil pressure due to the gauge not working and did not want to tear anything up. I checked the oil and had plenty. I went to restart my truck and all I got was a click, the engine did not even roll over. The windsheild wipers also came on, however, I did not have them turned on.
Any ideas on what went wrong or where I can start looking?
Old 01-22-2011, 07:07 PM
fuelman's Avatar
fuelman
fuelman is offline
Ground wires check as many as you can find, on the engine,firewall, under the dash at the power ditribution box. Check all fuses also.
Old 01-22-2011, 09:03 PM
Jackemupjoe's Avatar
Jackemupjoe
Jackemupjoe is offline
i agree it sounds like an electrical issue make sure you use a test light on the fuses and check both sides dont just look at them. let us know what you find out
Old 01-23-2011, 05:34 AM
DWilliams27's Avatar
DWilliams27
DWilliams27 is offline
Dead cell battery could be the issue as well. It can cause random electrical surges that cause random things to work/not work.
Old 01-23-2011, 06:14 AM
itsabowtime2's Avatar
itsabowtime2
itsabowtime2 is offline
The gauge not working in and by itself would not cause you tp loose oil pressure.
I would start with the battery. One or more bad cells could cause that. The wipers still working could happen as they draw much less power than the starter.
Old 01-23-2011, 06:45 AM
shorebird's Avatar
shorebird
shorebird is offline
Bad alternator leaving you on battery power until the battery drained below 10volts.
Old 01-23-2011, 07:16 AM
DWilliams27
Sounds more like a dead cell battery honestly, not saying the alternator isn't bad as well, but it is less likely to be the root of your problem considering the wipers came on without you turning them on.
Old 01-23-2011, 10:10 AM
kirk shonk's Avatar
kirk shonk
kirk shonk is offline
possibly the ignition switch
Old 02-14-2011, 07:20 PM
doogy84's Avatar
doogy84
doogy84 is offline
I have a similar problem with my 2009 F-250 diesel. Sometimes when driving all the gauges stop working and it starts cycling through all the warning lights. The pickup continues to run. Once the pickup is shut off it takes a while to start again. When i turn the key it wont turn over and started doesnt click or anything. After waiting a while it will eventually start. Some mornings the pickup wont start, when this happens the glow plug light will not come on, wont turn over, the starter doesnt make any noise. Eventually it starts. The pickup also randomly will have no power. Less than impressed with the service and quality of this pickup.
427 fordman
86
09-11-2014 04:25 PM
linckeil
13
10-02-2013 11:10 AM
GB SISSON
23
06-08-2012 07:47 PM
trakman
02-04-2006 12:08 AM
Pilsbury
05-31-2002 09:39 PM
Quick Reply: I need you help PLEASE!!! Any input is great
