Carb identification
Old 03-22-2002, 10:20 PM
steelie's Avatar
steelie
steelie is offline
Carb identification
The 64 250 I purchased has a 2 barrel on the 292 inside. I dont know if its the original. My different ford catalogs show a holley 2300 or a ford 2100 carb. The rebiuld kit I bought looks more for the holley. Mine has the accelerator pump on the side in the front rather than on the bottom of the float bowl. The fuel line enters the front rather than from the side on the front. I have know name or numbers on the carb itself other than a sundial looking emblem on the right side if you were looking at it from the front. Is this the ford carb. :-X11
Old 03-23-2002, 09:03 AM
44dwarf's Avatar
44dwarf
44dwarf is offline
Carb identification
Yes sounds like a ford / auto lite carb. Look on the air horn just like holleys for numbers. right side just below the choke plate.
idle mix 1-1.5 turns out.
float 29/64 down from top of casting (no gasket!)
float wet 29/32
acel pump lever "inboard" hole
throlle acel hole #3
Above is for FORD carb after 66 it called autolite and setting very a little but kit should tell you.
Look for C6TF-* *=a,b,c,d,e,f, ect
Best of luck
44Dwarf
Old 03-25-2002, 06:48 PM
mk's Avatar
mk
mk is offline
Carb identification
That 'sundial' thing should have a number in the middle of it indicating the venturi diameter- ie 1.08 or 1.12("). There should also be a part number stamped on the left front side of the base under where the dashpot is usually mounted. It should start with a C4T or something close to that.
Old 03-30-2002, 04:48 PM
steelie's Avatar
steelie
steelie is offline
Carb identification
Thinks for the input Ifound a chiltons for 60's trucks and the ford model is exactly what it is. With the illustrations on the settings for it its going to go better then i thought rebuilding it.
Old 03-31-2002, 01:12 AM
mwc4275's Avatar
mwc4275
mwc4275 is offline
Carb identification
brian eiland
43
03-03-2016 07:06 PM
423billyc
01-13-2013 06:04 PM
Condor945
43
03-08-2012 06:32 PM
68Ford4Life
20
01-18-2012 04:26 PM
bstanke39
09-09-2003 06:35 AM
Quick Reply: Carb identification
