Throwout bearing
Throwout bearing
I've got a '65 F100 with a 240 hooked up to a Ford medium duty 3 speed transmission. I'm getting noise when I get past the free play in the clutch pedal. Is this most likely the throwout bearing? How involved is it to drop the tranny and get to the clutch? Would I be better off taking it to the local transmission shop? Any insight would be appreciated- Tom.
Throwout bearing
Tom it does sound like your throwout bearing is noisey. It is not a very complicated job. I don't know what your mechanical skill level is but it is a job a relative newcomer can handle. If your unsure of your skills get a service manual or recriut some experienced help. You might as well do the whole clutch job while your there and don't neglect to machine the flywheel too. Complete clutch kits are available with all the parts you need and usually include a clutch aligning tool. Good luck, Rich.
mklemin
15
03-30-2008 11:46 PM
WhiteWolf
07-21-2004 06:53 PM
sam_1857
05-28-2002 11:27 PM
BigBrownTruck
03-26-2001 12:13 AM
