Sanding Cracks and Crevices
Old 08-25-2006, 07:53 PM
Matt66's Avatar
Matt66
Matt66 is offline
What is the best way to sand cracks and crevices that have some surface rust on them. Places like the rain gutters and such that are hard to manipulate into.
Thanks, Matt
Old 08-27-2006, 06:14 AM
Greg 79 f150's Avatar
Greg 79 f150
Greg 79 f150 is offline
Get creative. Use wood paint sticks or popsicle sticks to wrap the sandpaper around them, or make minifolds in the sandpaper to duplicate the sheetmetal form. Some people may even use a Dremel tool, but they may cut gouges in the metal because of the high speed of the tool and lack of total control of the abrasive disc....
Prep is 98 % of the hard work required for a total paint job, and the most labor intensive part of it. No real easy way out for crack and crevice sanding, other than media blasting. Even if that is done, there is the risk the novice user may warp the metal from heat friction caused by the media hitting the metal for too long in one spot. good luck
Old 08-27-2006, 03:25 PM
Matt66's Avatar
Matt66
Matt66 is offline
Thanks for the ideas.
Old 08-27-2006, 04:17 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
Have used dowels cut to desired length. Most auto paint stores have assortment of sanding blocks. Purchased 'tear drop' shaped sanding block and found it came in handy. Also, have assortment of felt 'bobs', come in various shape and sizes; cone, cylindrical, tree shaped, etc, and tube of greaseless abrasive, come in 80-320 grit, can get into some hard to reach places. As greg mentioned, get creative.
dave
Old 08-31-2006, 09:02 PM
mississauga's Avatar
mississauga
mississauga is offline
Great advice. To add, around the rain gutters you may find some seam sealer. I removed mine where it had cracks and discovered some rust underneath. Removed the rust and applied new seam sealer. You can smooth it with some wax and grease remover on you finger to act as a lubricant.
Flip4ford
Kansas Chapter
43
07-26-2018 06:43 AM
avf100
09-04-2016 01:45 PM
Diff
06-18-2016 07:21 PM
DHuskic
58
02-28-2015 07:18 AM
Nightrain
Paint & Bodywork
08-09-2007 10:45 PM
Quick Reply: Sanding Cracks and Crevices
