Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-25-2006, 06:27 PM
AndysFords AndysFords is offline
Garage is empty, add now
AndysFords is starting off with a positive reputation.
Sams Vegetable oil
I am going to start making biodiesel and I was going to start by making small amounts as test subjects. before i start collecting oil I wanted to use Sams frying oil just to get started. But what I couldn't figure out, how many gallons are in 35 pounds. Nowhere on the box does it say gallons. I believe it was $13 for 35 pounds.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #2 (permalink)
Old 08-25-2006, 07:50 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Most cooking oils weigh about 7 lbs/gallon.
35lbs dev 7lbs = 5 gallons, 5 gal @ $13 = $2.60/ gallon.
Good luck! Keep us informed on your progress.............
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 08-26-2006, 07:56 AM
MobeyDick MobeyDick is offline
MobeyDick is starting off with a positive reputation.
I measured it out and got 4.5 gallons, it says Cost per Fluid ounce is 2.268321 cent that wound put it at 588.1 Fluid ounces or 4.59453 Gallons! I stand by 4.5 though because that is what I measured. That is what I use when I calculate fuel mileage. I come up with $2.964 per Gallon!
BTW: Down south it's $13.34 for 35 Pounds.
__________________
05 6.0 Reg cab 173,00 miles! -07 Shelby GT500-
  #4 (permalink)
Old 08-26-2006, 10:11 AM
Dave Barbieri Dave Barbieri is offline
Dave Barbieri is starting off with a positive reputation.
Yeah, I've been using Sam's oil for my first batches. It takes out a couple of variables. Because it's new, I use much less NOH, so the lye lasts much longer. I initially asked the list if someone had measured it, and the general response seemed to be 4.3 gallons. In using a carboy to check that, I've found it to be pretty close. 4.5 gallons sounds right in the ballpark!
The Mercedes folks on the west coast report that they can buy veggie oil from CostCo for around $2.45/gallon. The SVO folks are WAY happy!
__________________
1985 F250 XL 6.9
T-19 4 spd, A/C, PW, CC
  #5 (permalink)
Old 08-26-2006, 09:12 PM
Drag_N_Fly_One Drag_N_Fly_One is offline
Drag_N_Fly_One is starting off with a positive reputation.
Hey, if one decided to use NEW vo to make bio, would you end up using less KOH and methanol ?
  #6 (permalink)
Old 08-26-2006, 09:25 PM
Quote:
Same amount of methanol - that stays constant at 20% - 22% of your vegetable oil. It's the KOH/NOH that changes . My titrations on Sam's clear fryer oil had me adding only 19.7 grams/.04 pounds per gallon of oil. In a 30 gallon batch, that came out as:
30 gallons/7 containers of oil
6.5 gallons of methanol
1.2 pounds of lye
3 batches so far. I air wash/bubble for 24 hours, skimming soap manually, then filtering thru 10 micron bag filters. I then let the fuel bubble overnight. I pump the bio from the barrel thru a 2 micron water block filter and into my fuel tank. Crystal clear, no soap, burns great.
__________________
1985 F250 XL 6.9
  #7 (permalink)
Old 09-01-2006, 12:10 PM
OK, now I've got some new veggie oil, what else do I need to make some test batches of Biodiesel? Where do you buy Lye, and how hard is it to use ethanol istead of methanol? I am also starting to make ethanol for some of my old trucks so this would be a lot easier and cheaper.
__________________
  #8 (permalink)
Old 09-03-2006, 11:31 AM
Sorry for the delayed reply. Here's some info that might be helpful.
I buy my methanol from David's Auto Center on Hwy 69. He reaces dirt track on the weekends, so he keeps a 600 gallon tank of the stuff for himself and his friends. My last 55 gal barrel cost me about $120.
I use NOH (lye) for my reaction, and I pick it up at Lowe's. Look for Roebic Crystal Drain Opener. It's in granular form and comes in a 32oz/2 pound/908 gram plastic bottle. I think I paid $7 and change for each bottle. Not too sure - can't find the receipt. You can find it back in the plumbing area, about one row before the water heaters. It's on a shelf with a bunch of other drain cleaner/opener products.
I'm still looking for a source of filtered oil. I'm trying to talk to the collection services. As a last resort, I'll pick up my own. I'd rather pay a little up front for each gallon of oil and NOT have to deal with 'residue' (ie: french fries, fish heads, corn meal, etc). Also, here's a real interesting source for info and bio:
http://www.houstonbiodiesel.com/
These folks are located on the north side of Houston in a reclaimed junk yard. They offer classes on specific Saturday's each month, and they also sell bioD. Their website lists the current prices; right now it's $2.68 for B99 and $3 for B100. I'm thinking it'd be a hoot to go down there, take a class and then top off the truck and a few barrels with some real ASTM-spec bioD! After half-a-dozen batches, I've got some questions about titration. Reading about it on the net is one thing, seeing it in person is another. Plus, it'd be fun to talk to folks who've been doing this successfully for a while. I'm thinking one Saturday in October.
Hope this helps!
__________________
1985 F250 XL 6.9
  #9 (permalink)
Old 09-03-2006, 08:02 PM
1935 Ford pickup
You should go here first: http://www.biodieselcommunity.org
Very good site for Biodiesel info. You can use Ethanol to make Biodiesel, BUT it has to be 99.5 percent. Even My reflux still only makes 95 percent Ethanol, you have to put it through a molecular sieve to get the needed purity for making Biodiesel.
FABMANDELUX.
__________________
Tags
2010, 55, barbieri, dave, f250, f350, ford, fuel, gals, mileage, oil, sams, vegetable, vegitable, vegtable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
