piston wrist pin differences?
Floating pin pistons are fitted with retaining rings in the pistons.
http://www.tpub.com/content/engine/1.../14037_104.htm
Floating wrist pins also require bushed rods. The bushings in my stroker rods are bronze. The floating pins actually rotate, wearing and making an oval out of the small end of the rod. The bushings are an interference fit, and can be pressed out and replaced when worn. My pistons also use larger .927 diameter pins, as opposed to the stock .912. They're a little heavier, made from tool steel, and have a thicker wall. Floating pins allow the piston to move more freely, reducing friction losses, but they can also contribute to piston "slap" against the cylinder walls. To combat this, I went with teflon coated, full-skirt forged pistons. These features allow you to run tighter piston-to bore clearances, which also enhances ring seal and stability. Press fit pin side-to-side movement is limited by the pin bosses that are cast into the bottom of the piston.
Pete
Pete
Kyle Wood
11-18-2016 05:38 AM
Anthonynoble
01-25-2016 06:08 AM
