two questions for the volare front suspension crew
It's me again , lol . Anyways here's the questions . (1) How did you fabricate your power steering pump brackets? I am running a 302 and am planning on using the mopar power steering pump , problem is the bracketing nothing even closely is the same . Anyone have photos in their galleries? (2) I also am mocking up a steering column without getting into the big buck stuff ( although I will consider those options) what type did you use and do you have photos of how the type of column mounts in the dash and steering box sections ? I was going to use a granada column that I had but it is way too short( it won't even go through the floor when it's at a good driving height. Any thoughts guys ? thanks !!!
My son's 63 has a Volare' in it with a 302. We used the stock 86 302 power steering pump and used the pressure hose from a Crown Victoria. It bolted in after tweaking the tube for clearance.
His truck uses the column from a 75-91 Ford van. Again his is a 63 so that may not be a direct fit in yours. I used the tilt column from a Camaro in my 56. I wanted a floor shifter is one reason I used the Camaro guts. It had a 73 LTD tilt column in it before that.
on
I used the Chrysler pump on a SBC in my 48 with Volare suspension. Even though the brackets are entirely different you will find that the pump has a number of mounting holes for different types of brackets. I believe the Chrysler pumps are made by Saginaw which are also used on a variety of vehicle makes. The approach I took was to tweek the GM bracket to make it hold the Chrysler pump. You should be able to do the same with a Ford bracket. The hardest part I found was in getting the belt alignment perfect. I'm sure you can do it with some time and patience...
Vern
Vern
Why do you want a chrys pump??? Find the ford pump and brackets to fit your engine and then get the adjustable valve. PS: The GM pump is the Chrysler pump and they do interchange, I did it. It was a waste of time and effort. It had the same guts, valving and preload spring, just a different shaft. press vs. splined.
cabby daddy , thanks . And El Cabron , the reason that I didn't go with the ford pump was awhile back on this site someone claimed that when they used the ford one it made the steering way too quick ??????????????? So I thought that I would ask for more info . Your adjustable valving solution just might be what that last guy overlooked . Thanks
on
Vern
Well, after I read those threads, I went out and found the CH pump but the housing does not fit the GM brackets, and it was then I found the CH pump will fit right into the GM housing and bolt back into the GM brackets. It was while I had both units apart that I found both pumps, valves and chech ball spring preload to be identical. The check valve and spring tensions were checked at a machine shop on test equipment. To further verify, I bought an additional GM housing as to have 2 GM housings ( 1 GM pump, 1 CH pump ) and change back and forth to test the steering and there was no difference or change in the feel of the steering. In short, if the housing fit the bracket, you can then choose either pump to go into the housing. And, the GM shaft is splined, the CHR is press on. The pumps are even the same casting when laid side by side. Weird. Furthermore, it is actually the R & P steering that requires less pump pressure and will need the adjustable in-line valve.
I had a DEVIL of a time trying to figure this one out as well. I finally ended up going to the junkyard and finding a PS bracket that fit my engine. I then bought a new PS pump and installed it. Shimming the thing to fit my pulleys was a bit tricky, and now I just need to get a hose that goes from a Ford pump to the Volare box.
Im using an Ididit tilt column. Money well spent.
~Rich
~Rich
It takes a min. column length of 32" to get to the other side of the firewall.
To check pulley alignment lay a straight edge across both pulley faces, when it touches both edges of both pulleys at the same time they are aligned.
52' fordnut
12-10-2012 07:51 PM
willys_gasser
07-29-2008 06:34 AM
rick
02-23-2000 10:43 PM
