Parking Brake Light Stays On
It's an 02 7.3 6 speed, CC. I got some bum scoop it would seem and now I'm paying for it. I should have stuck to the old saying, "If it's working fine, don't mess with it!" I also disconnected batteries, still no change. Took it for a test drive and the light went out for about 5 seconds then came back on. I have a extra brake light mounted in the trailer hitch receiver, now it comes on when lights are turned on.
Bill
Bill
on
Brake Light
I don't really know what you mean by "read it out", but make sure that you have enough fluid in the master cylinder. If the fluid is full, remove the cap, and using a clean screwdriver, push the float down inside the cylinder and then let it float up. If it seems stuck, rap the side of the reservoir with the screwdriver handle. As long as that float is up, your light should be off, unless the switch got screwed up when you disconnected it.
RON
RON
Bill
Just bringing this to the top again. I still have a constant brake light, the red one. Everything else works fine except the brake light in the hitch receiver. It comes on with the light switch? My 02 doesn't have a GEM instead it has a VSM and instrument cluster system? The constant brake light is annoying. There are no code either.
Bill
Bill
jake_c_19
01-11-2014 06:54 PM
