'65 f100-4x4
'65 f100-4x4
As far as I know, ALL '65 Ford 4 x 4s were "factory". In the late '50s, Ford got away from using Marmon-Harrington for their 4 x 4 conversions. The VIN tag should be on your driver's door. If the VIN does not match your truck, consider that maybe someone swapped the door at one time and didn't swap the tags..
'65 f100-4x4
There are several things you can check quite easily that will tell you if your truck is a factory 4x4. With the exception of some 66 F100 4x4s, the 61 to 66 F100s and F250s came with 120 inch wheel base, the 57 to 60 model years box (for styleside), the 61 to 64 cab with step-up and higher center hump and the 61 to 64 style inner fenders. Check the VIN stamped on the top of the right frame rail at or near the right front wheel. If it starts with F11 or F26 as jjb stated, you have a factory 4x4 frame. The F100 transfer case was a single speed while the F250 was a two speed, 4H and 4L.
Rbeck204
11-26-2015 02:39 AM
