Starter keeps spinning
Originally Posted by ZOMBIESTOMP
My 87 f-150 starter keeps spinning even with ignition off have replaced the solenoid. Even tried several solenoids thinking I had bought a bad one ,Still same problem ! can anyone help?
If its fuel injected, you must have a solenoid with a built in diode. The diode absorbs the residual voltage that the ECM applies to the wire that energizes the solenoid. If you have the right solenoid, the wire that energizes it obviously is shorted to some other wire in the harness that has above 10 volts, or, it could be an interrnal defect inside the ignition switch.
Phil
Phil
abe
03-23-2015 10:26 AM
Windstorm
09-17-2014 10:22 AM
rpaxton939
04-09-2014 08:15 PM
cityjack
02-09-2014 08:49 PM
