You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just received my first oil report and the only issue is the lead was high.
Oil is shell 5 40 sample pulled @ 3500 miles. Most of the mileage was pulling my fifth wheel with a weight of 12K. Burned 155 gallons of WVO and 145 gallons of diesel.
Is anyone else having their engine oil tested?
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Could be turbo bearings going. Any mods to the turbo?
Also, watching for trends is the biggest and best thing about
UOA's. Being your first it's hard to say too much.
Nut
My lead was 24 and all other metals were with in normal.
Only mods on engine is air intake and heated WVO system.
Nut
__________________
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I just got my report back with a lead high of 10ppm. It is from the bearings. rods/mains.
I tow 10,000 trailer and run straight diesel fuel. I use Rotella 15-40 oil. I change it every 5,000 miles. I called Blackstone and talked to the tech. He said I should change the oil just BEFORE going on a heavy towing trip. NOT after. I will send them a sample after 4,000 miles and see what count is then.
My 2004 E-350 SD van with 6.0 Ford engine has a 100,000 mile warrantee. I would never try to use other crap with the fuel including veggie fuel. Don't want to mess up the warrantee. I get about 12 mpg pulling that load and 15-16mpg around town. I am retired and on a small fixed income. I do not want to have to pay heavy repair bills.
I am thinking about going to synthetic crank case oil. I will talk to Blackstone before trying that.
Bruce
__________________
Bruce Saylor
2004 E-350 Super Duty
Standard Van
with 6.0 diesel
LTD slip 3:55 Rear
The Blackstone report said they could not tell where the lead came from.
All other metals were below normal. They said if it was from the bearings there should have been other metals with it.
I hear you on keeping you engine warrantee intact. I know converting and running WVO is a risk. I have about 5,000 miles of running WVO with out any issues
Bruce
__________________
