Super Duty Turning Radius - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-21-2006, 10:56 PM
Trouble1263's Avatar
Trouble1263 Trouble1263 is offline
Journeyman Lurker
Trouble1263 is starting off with a positive reputation.
Question Super Duty Turning Radius
Hey Guys,Is there a way to decrease the turning radius on these super duties? I need a parking lot to perform a U-Turn. My work truck(IHC 4300 Series 26,000 GVW) can turn in a much smaller arc than my pick-up. What was Ford thinking when they designed this????? Great site, look forward to the discussion..
Old 08-21-2006, 11:07 PM
CarlF250 CarlF250 is offline
CarlF250 is starting off with a positive reputation.
Welcome to the world of heavy duty trucks with leaf springs up front! I see by your profile that you have a 2001 Super Duty. Im assuming its a 4x4. I think the newer 4x4 trucks have coils up front which I think allows a tighter turning radius. I'm not sure. I have a 2002 F250 4x4 with leafs and I know what you mean. It rides like a tank, doesn't turn tight, but it rides real high and looks cool.
Old 08-21-2006, 11:15 PM
blueiron blueiron is offline
blueiron is starting off with a positive reputation.
The new Super Duty trucks do have a tighter turning radius due to the coil spring front suspension, but it will never be known for turning on a dime.
Old 08-21-2006, 11:22 PM
PHWLEE's Avatar
PHWLEE PHWLEE is offline
PHWLEE is starting off with a positive reputation.
Smile
Quote:
Your last line says it all.
Old 08-22-2006, 10:20 AM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Along with my '06, I've driven an '02 at work. The '06 turns WAY sharper than the '02. Both are long bed crew cabs.
Old 08-22-2006, 11:02 AM
Autobahn F-250 Lariat's Avatar
Autobahn F-250 Lariat Autobahn F-250 Lariat is offline
Autobahn F-250 Lariat is starting off with a positive reputation.
SD turning radius about 40 acres
Old 08-22-2006, 03:18 PM
Lonewolftx's Avatar
Lonewolftx Lonewolftx is offline
Lonewolftx is gaining momentum as a positive member of FTE.Lonewolftx is gaining momentum as a positive member of FTE.
You can always drive a Ranger. The '06 turning radius was decreased by 5'1" in '06 as they brought the design in line w/in the springs
Old 08-22-2006, 04:19 PM
sifon187's Avatar
sifon187 sifon187 is offline
sifon187 is starting off with a positive reputation.
I have a 03 f250 Screw shortbox and I was suprised that I could even do a clean U'ey on a four lane intersection. Its alot better then I thought it would be. Theres always a negitive to driving a kick a** truck like we do. But its worth it because there isnt anything cooler then a f250 or f350 going down the road.
think these will work??? radius arms lindner115 1999 to 2016 Super Duty 0 11-03-2016 03:03 PM
Lift question. slim813 1999 to 2016 Super Duty 5 08-29-2016 02:38 PM
2016 F250 Turning Radius Nipperdog 6.7L Power Stroke Diesel 2 11-01-2015 12:21 PM
Possible to improve turning radius? 1978Crew 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-20-2007 01:03 AM
Cross Drilled & Slotted Aero Rotors 96_4wdr Aerostar 3 03-22-2006 04:07 AM
Tags
04, back, decrease, decreasing, duty, f150, heavy, radius, ranger, super, superduty, tighter, trucks, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
