3.73 gears or 3.90's
I am wondering what would be a better choice for gears in my truck. It is a 06 F150 4.2 and a 5speed manual. It currently has 3.55's in it and oversized tires and wheels. Since the tires and wheels it feels like it lost its low end. I am currently only thinking obout 3.73's or 3.90's. It can't break the tires lose unless I am doing 5-10mph, which leads me to suspect a to high of a gear ratio. I do drive alot in the country, city and on the highway, but if I do go on the highway then it is only when I am heading up into the Sierras (siera mountain range). So there are some prety steep hills. I am more of a performance driver and like it to be a quik and respnsive truck. It has bad throttle response when I am driving and floor it.
There is very little percentage difference between 3.55, 3.73, 3.90. I agree with wheelMA1. 4.10 will increase your highway RPM about 300 if I calculate correctly. ESP with the 4.2 and a 5 speed, I bet it will make the truck lots of fun.
Personally, I want to go with a 4.30 and a 33 inch tire. That should be close to my stock tire and a 4.10. With a good mix of highway and city driving, I'll bet that the MPG's are close to the same if not a smidge better than what you get now.
How would going from 3.55 to 4.10 do to my gas millage? I would have higher rpm's, but I would have to give it less gas for acceleration especially in the city. It should hurt the highway a little but improve the city theoretically of course, I would think??
After putting 4.10 into the calculator it really looks good. It will raise the RPM's a little over 500rpm in fourth and a little less than 300 in OD. It makes much less of a difference than I thought, and if I put 3.73 or 3.90 I wouldn't notice a whole lot. I will shift out of first at about 18mph instead of 22mph, which isn't a huge difference but what I was looking for. It should be even better than stock.
OH, almost forgot it is just a little regular cab 2wd so I only have to do the one differencial.
I am extremely proud tha your 4.2 can spin a tire. I have 295/45/20 on there and if you floor it, it will not even attempt to spin a tire. The only time I can spin a tire is when I have the engine revving pretty hard. My truck has no bottom end what soever. If you plan on upgradign in the futer I would get 4.56. If you are happy with your 33 and have no intentions on upgrading get the 4.10. This would bring you back to where you were stock but I see no need to replace your gears in two months when you will get bored and eventually go with a taller tire. Just my suggestion to plan for the future of your vehicle. Proud that a 4.2 can spin a tire, my silly automatic has to much lag.
I wouldnt be scared at all to run 4.56s in these newer trucks. In my lowered 04 i had planned for 4.56 gears with tires about 32 inches or so. I know it sounds high, but many friends of mine have 4.56 gears in their trucks and are reporting great power transfer and their mileage is hardly affected at all.
I went from 3.55 to 3.73, and didnt feel a thing. I wouldnt be at all concerned with going with 4.56 gears
As far as the cost, expect to pay around $200-250 per axle on the ring an pinion, another $100-150 per axle for the install kits (bearings, seals, crush sleeves, etc.) and anywhere from $200-400 per axle for installation. On your truck, you should have the 8.8 31 spine rear, which means that gears and install kits will be a little cheaper and easier to find than those with the 9.75 rear.
I am planning for the 4.10's and they are about 185.00-200.00 for a set plus the install kit and the install itself. I'm lucky to only have 2wd for this gear change. I hope it will spin the tires since before the only time I could spin the tires was when the street was wet or if I started on dirt and then on to pavement, if I get them going in dirt then it does fine on the pavement and doesn't slow down the tires.
I have heard from many other people that the V6 with an auto is gutless.
Skygrasper
02-12-2019 11:24 AM
