Keyless Entry Lost Code - Ford Truck Enthusiasts Forums
Old 08-21-2006, 02:29 PM
shooser555 shooser555 is offline
shooser555 is starting off with a positive reputation.
I have a 2003 Explorer with the Factory Keyless Entry on the driver's door. It recently quit working with either my code or the factory code. I have cleared my code, and the only response is that the keypad will light up, and I can lock all doors with the pad. It refuses to take a code to unlock. Any ideas other than the dealer route ( and a possible new GEM)? The wireless remotes continue to work well. Thanks for your help!!!
Old 08-21-2006, 09:58 PM
JerrySimm JerrySimm is offline
JerrySimm is starting off with a positive reputation.
What happens if you disconnect the battery for 30 minutes?
Old 08-22-2006, 06:05 PM
screwy's Avatar
screwy screwy is online now
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Chances are one of the buttons has quit working, test each button while the lights are off, if you find one doesn’t trigger the lights to come on you've found your problem.
Old 08-23-2006, 12:16 AM
MazdaRangerGuy MazdaRangerGuy is offline
MazdaRangerGuy is starting off with a positive reputation.
the button contacts are a very weak point in those pads. Sometimes moisture gets behind there and corrodes them. You might try to locate the GEM under the dash.. it should have the factory code printed on the housing. You might be punching in the wrong code.
Good luck
Old 08-23-2006, 04:28 PM
bren bren is offline
bren is starting off with a positive reputation.
I bought a lease back 03 Sport Track XLT - without an owners manuel - can someone advise me on how to reset my keypad so I can utilize this?
Also, having difficulty with my tonneau cover - removed it completely to move some furniture and once back in place - have been having difficulty with locking the set next to the cab - the other end locks fine?
one more question!!! how does the Shuffle for the 6 CD work??? I was told to push one and load - push two and load etc....haven't been able to try it just yet today -
So any ideas on the above would be awesome - thanks!
Old 08-24-2006, 03:02 AM
Nasty350LT1 Nasty350LT1 is offline
Nasty350LT1 is starting off with a positive reputation.
Here you go...
Once you enter the code, the driver's door will unlock. If you press the 3-4 button within 5 seconds, the other doors will unlock. Press the 5-6 button within 5 seconds, and the rear window will release. Press the 7-8 button within 5 seconds, and the front bumper falls off. No- just kidding. Actually, if you press the 7-8 and 9-0 buttons together, it will lock all the doors. If you want to add your own personal code, enter the code you found on the module, and then press 1. Within 5 seconds, enter the 5-digit code you want to add. The doors will lock, then unlock, confirming it has accepted the new additional code. Now both codes will work, and entering your own personal code is the same as entering the master code. To unlock the other doors, press 3-4 within 5 seconds, etc... Be careful in the personal code you choose; you can't use 5 of the same number (77777, for example), and don't use one that goes in sequence (14580, for example). People will come up and tend to push the buttons in sequence to try and get in.
Old 08-31-2014, 10:35 AM
tom50mg's Avatar
tom50mg tom50mg is offline
tom50mg is starting off with a positive reputation.
On my 2003 explorer I found the code for the keypad behind the right rear door panel,but the pad still wont work for me...pulling out my hair right now!
Old 09-02-2014, 07:55 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Have you tried pressing the 7-8 and 9-0 buttons at the same time to see if that locks all doors? Make sure you don't lock the keys in the truck when doing this! The backlighting for the keypad buttons should come on as well.
If that locks all doors, then at least you know the keypad is connected and the RKE system is at least partially working. If that does not work, then you might start by checking fuses. The next step might be to inspect the wires in the accordion boot for ones that are broken or have kinks, indicating broken copper under the insulation.
Is there any evidence this door has been replaced?
-Rod
Old 09-02-2014, 08:23 AM
tom50mg's Avatar
keyless entry
I was checking to see if the backlights lit up and low and behold the 1_2 button did not light,printed circuit inside of the pad,strong suspition this is the problem,will order one today from the dealer,will let you know the results,thanks!
Old 09-04-2014, 06:53 AM
tom50mg's Avatar
I changed the keyless key pad yesterday and the 1-2 button still did,nt light up and would not unlock the doors,i peeled back the boot between the door and the post,there has been work done there before,now to try and find a wiring diagram and try to find the right color wire to trace! Anyone have a schematic I can use...thanks in advance.
Old 09-04-2014, 07:49 AM
shorod's Avatar
Yep, I should be able to provide the factory wiring diagram for the keypad. Just sent me a Private Message with the request AND an e-mail address to send the PDF to.
-Rod
Old 09-04-2014, 05:55 PM
tom50mg's Avatar
Quote:
-Rod
Thanks a lot Rod,my e-mail address is tom 50mg@gmail.com
Old 09-04-2014, 05:57 PM
tom50mg's Avatar
oh ya,requesting the wiring diagram for the keyless entry pad for a 2003 explorer...thanks again!tom50mg@gmail.com
Old 09-04-2014, 11:53 PM
shorod's Avatar
I'm not totally positive I deciphered the e-mail address correctly. I e-mailed the files to tom50mg@gmail.com
-Rod
Old 09-05-2014, 12:30 AM
gijim2k1's Avatar
gijim2k1 gijim2k1 is offline
gijim2k1 is starting off with a positive reputation.
Quote:
And here I thought it was because of rust......
2008 6.8L F250 Crew Cab Keyless entry onelowhog 1999 to 2016 Super Duty 0 02-20-2016 02:11 PM
Autoenginuity keyless entry cassenbl Excursion - King of SUVs 13 04-07-2015 01:33 PM
2006 Keyless Entry on the door help. SolarKing 1999 to 2016 Super Duty 9 01-12-2015 06:23 PM
Door Keyless Entry Help!!! fx4king2011 2009 - 2014 F150 1 08-30-2014 10:21 AM
Keyless entry issues akaFrankCastle Excursion - King of SUVs 0 12-05-2012 01:37 PM
Tags
code, door, entry, ford, keyless, lost, punched, truck, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
