6.0 Diesel Injector Failure
I would recommend you use the Search function. Probably find plenty of reading (or not) right away rather than waiting for this thread to develop (or not).
FWIW, other than the 2003 models having some problems I don't think I've seen many posts with injector problems, nothing like an epidemic or anything anyway.
hey guys just a question here did you guys get any check engine light's when your fuel injectors went out? another i have a 03 6.0L f-350 and im having some issues it runs like crap till it gets warmed up then you can drive it but a huge powerloss! you cant even throttle it till it warms it will not rev up when it's cold!!!
????????anyhelp would be great!
I have replaced 5 injectors in my 04 PSD F350. I did not get any check engine lights when the failure happened.
I had 4 injectors crap out on me in Mexico, just south of Ensenada. I was pulling a boat and had 4 guys and all of our crap from a week long fishing/camping trip in the truck as well.
The symptoms: The truck started to idle rough and then it died. I was able to pull over and kept trying to start it. This went on for about 2 hours when I finally was able to get it started it ran but rough. I was able to make it back across the board with 4 injectors shot. Seems like a pretty tough truck to be able to pull that load will only half the power/fuel.
ya it sounds like my problem runs rough like injectors are not pushin enough fuel!!! ya my injectors went out in tulsa ,ok and ford dealership flushed out the oil system with over 60 quarts of oil at my expense and 2 oil filters and it ran all the way back to portland or and still runs that was 2 weeks ago!!! its currently in the shop and my mechanic say's to replace the injectors ,but not 100% sure if it will cure the problem (he's a good friend of mine who owns his own shop 99% of his work is on gas engines) so any help from you guys in ford land is so much appreciated!!!!! thanks alot i will taketo the ford dealer in portland to pin point each failed injector and replace them accordingly
Why??, are these injectors going bad? Is the fuel delivery system a bad design? Are the injectors a bad design? Is bad fuel causing these failures, if so, will fuel treatment help? What can I do to keep my injectors happy. I run Stanadyne in every tank. From reading numerous posts, the early 6.0's had faulty injectors, but only some folks had problems. Does my 11/05 build have the newest most up to date injectors for the 6.0? 4k so far and not a single blip....Love the truck~ Brad
