AJ46 Ihave been tring to PM you but the system, Says that I have not used enough posting and will not let me PM you or email you to confirm join request
Hello AJ46, go ahead and apply, I`ve been watching for your request.
Just submit your join request with a click on the Canadian National Chapter: http://www.ford-trucks.com/forums/forum164/ then click on join the Man/Sask chapter.
Hello. I've followed the links you provided, when I select join chapter it redirects me to a blank page with a small text at the bottom of the page that reads "done". I would PM you but pming abilities appear to be disabeled.
Hi and welcome.
I see no request to join so it`s not working, I tried to email you but I can`t as you may have your email access turned off. Check and see if you do have it turned off, if so then you`ll need to change it.
Go into your ''User CP'' then Edit Options and under Messaging & Notification you`ll see this:
Receive Email From time to time, the administrators may want to send you email notices.
If you do not want to receive these notices, disable this option.
Receive Email from Administrators
You can allow other members to send you email messages.
Receive Email from Other Members
__________________________
Put check marks in those boxes so you allow other members to send you email messages and to receive Email from Other Members.
Good luck!
Hmm... Odd I had it set to recieve messages from admins but I now have it set to recieve messages from any member. Thanks for your help. The join link still appears to be dead for the SK/MN chapter.
Actually the chapter is mostly a chat section......LOL!
Not too many members seem too interested in meetings, hopefully you are. Let me know.
If so let`s let`s call for a meet soon, like the 27-8th of June. Usually we met up at the 8th Street A&W after supper.
