Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-20-2006, 01:23 PM
schmity schmity is offline
Garage is empty, add now
schmity is starting off with a positive reputation.
The nuts and bolts of Making Biodiesel
Newbie here! I've noticed that most of the biodiesel sites give a general description of how biodiesel is made and step-by-step procedures for making it. Where can I find more in-depth and technical information about it?
__________________
02 DRW 4DR PSD, 4.10 Lim. Slip, DP 4pos Chip, Tymar Intake, CCV vented @ spare tire, Magnaflow exhaust, GT38r with gutted EBPV, Gutted Turbo Pedestal, AIH "sawed off", DI regulated Return, Spearco 6.0 IC, Dieselsite boot kit.
  #2 (permalink)
Old 08-20-2006, 05:39 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Try here first: http://www.biodieselcommunity.org
Or here: http://www.biodiesel.org/
Or here: http://biodiesel.infopop.cc/eve/forums
Or here: http://www.me.iastate.edu/biodiesel/...iodiesel1.html
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 08-20-2006, 05:42 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Here are a few
http://www.biodieselcommunity.org/mainpage/
http://www.localb100.com/
Girl Marks book "Biodiesel Homebrew Guide" is available here and highly recommended
http://www.journeytoforever.org/biod...make.html#2svo
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #4 (permalink)
Old 08-21-2006, 09:11 PM
Thanks, that should get me started.
__________________
  #5 (permalink)
Old 08-24-2006, 10:40 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Follow fabmans instructions
for every 25 gallons of wvo
5 gallons of methanol
3 lb on Potassium Hydroxide
heat oil to 150
mix methanol and Pot seperate for about 1/2 hour ---no sparks no breathing
add to hot oil and mix for hour---move to holding tank for seperation time
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #6 (permalink)
Old 08-30-2006, 08:37 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Quote:
How much seperation time, assuming one is not interested in washing the fuel?
Where does that hydrocyclone deal fit into the mix...or does it?
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #7 (permalink)
Old 08-30-2006, 08:50 PM
1935 Ford pickup
Evening Scott: The first seperation is to remove the Glycerol, and is complete in about 12 hours. Then I let the biodiesel "set" for 30 days, which allows the soap to fall out of suspension, and the excess Methanol to evaporate.
I no longer use that system. Now I use the Hydrocyclone to remove the glycerol within about 30 min, then remove the Methanol by vacume, which allows the soap to drop out. After the soap is removed I use Magnesol to finish cleaning the Biodiesel.
By removing the Methanol I've upped my Methanol recovery rate to 35 - 40 percent, and use less Magnesol.
FABMANDELUX.
__________________
  #8 (permalink)
Old 08-30-2006, 09:10 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Great info Don, Thank you!!
I don't see anything in you gallery that I recognize as a vacuum chamber. Did I just miss it?
On your initial set up, after the the 30 days did you just draw the fuel off the top straight into the tank, or was there an additional filtering step before it's burned?
__________________
Scott
  #9 (permalink)
Old 08-30-2006, 09:42 PM
1935 Ford pickup
You didn't see it cause I haven't posted them yet
Yes, I do filter the bio after settleing. First through a 5 micron, then a 1 micron filter. My main tank has a bottom drain for water and "slime" and the main outlet is 6" off the bottom.
FABMANDELUX.
__________________
  #10 (permalink)
Old 08-30-2006, 10:44 PM
Why are you still using magnesol with the vacume? Should the 15lb of vacume remove the rest of the water almost instant? Hmmm.
Found my new vacume pump in my dads junk..I mean back yard. Pulls 30lbs...FREEBEE
So far my cost has mainly been in chemicals and pvc.
__________________
  #11 (permalink)
Old 08-30-2006, 10:56 PM
1935 Ford pickup
Ah, grasshoppa. One must take ALL of the junk out, if one wants to make ASTM fuel
[ and it's INCHES of vacume]
FABMANDELUX.
__________________
  #12 (permalink)
Old 08-31-2006, 08:28 PM
superrangerman2002 superrangerman2002 is offline
superrangerman2002 is gaining momentum as a positive member of FTE.
heat oil to 150
Whoa, that's way, way, way too much KaOH. A really good way to make soap if you have water present.
Methanol is usually 22% by total volume of oil and 4 grams lye per liter of new oil oil, or 4 grams of lye PLUS 1 gram per ml added in a titration.
My last batch of Bio was 120 L (little over 30 gallons) only used 23L of methanol (IIRC) and 600 grams of NaOH (little over a pound).
150F is awful close to vaporizing methanol, 130F is usually considered a better reaction temperature.
__________________
'12 F250 Superduty CC 4x4 6.7L PSD
  #13 (permalink)
Old 08-31-2006, 10:13 PM
1935 Ford pickup
Kennedyford got that formula from me, It's the one I've been using for over 3 years, and 8,000+ gallons of Bio. The 4 gms Lye called for in the JTF site has been proven to be too low over and over again. The true base amount should be 5.5 gms/ltr FOR NEW OIL. Not all oils need the same base amount, they can vary by quite a bit, with "used" oil sometimes needing more gms/ltr.
The 5.5 gms/ltr does not apply for using KOH.
KOH requires the use of a base amount of 7.5 gms/ltr. It also depends on the purity of the KOH, mine is only 90 percent, so it requires more yet.
My oil is a "mix" of cannola, corn, soy, and olive oil. I run all my oil through a "rotary" pre-cleaner, de-waterer, then into a 400 gal main heating tank where it is heated to 150 deg F. once the heating cycle is complete, it goes through another "de-waterer" then to the 75 gal open mix tank. After only 30 min of mechanical mixing it is pumped through a Hydrocyclone to remove the glycerol. It then goes into the Methanol recovery tank where the Methanol is removed by vacume, and reclamed. The Biodiesel then goes into a 12 hr cooling cycle, after cooling, the soap is filtered out, and then into another mix tank where it is mixed with 1 percent Magnesol for 30 min. After the 30 min mix the Magnesol is filtered out and the biodiesel is ready for use.
As for the 150 deg temp, I've found that if you use 130 deg, the addition of room temp Methanol causes the "mix" temp to fall to low, and requires more mix time. I made 300 gallons today and will put it into the main storage tank for use tomorrow, with no wash water to dispose of.
FAABMANDELUX.
__________________
  #14 (permalink)
Old 09-24-2006, 07:35 AM
DUALLYNOTED DUALLYNOTED is offline
DUALLYNOTED is starting off with a positive reputation.
Exclamation Cost Of Equiptment?
What has this cost some of you to make??? what do you figure you're saving per gallon.
__________________
2000 F350 DUALLY CREWCAB 7.3 DIESEL 4X4...A TRUCK WITH A GAS ENGINE IS ONLY A CAR!
  #15 (permalink)
Old 09-24-2006, 09:25 AM
1935 Ford pickup
Quote:
I built my own equipment for less than $200. I've made over 8,000 gallons in about 3 years. My cost is $.38 - $.42 per gallon, and I smile every time I pass a service station
FABMANDELUX.
__________________
Tags
biodiesel, ford, glycerol, hydroclone, making, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
