F150 Humming noise when accelerating
Hello,
I just bought a 2003 F150 XLT (F4X Off Road series) and noticed that there is a humming noise that starts when I accelerate between 35 to 50 mph. Whenever I press the accelerator in that range, the humming begins and when I let-off the gas and coast, the noise stops. If I put it in neutral when I'm rolling in that range and hit the gas, I don't hear the noise. The humming seems to be coming from the underside bed area of the truck the best I can tell. Does anyone know the cause of this humming noise?? Thanks for your help
Thanks for the response. The truck has 52,000 miles on it.
Originally Posted by Racerguy
Hi and welcome to the forum
How many miles on the truck?
A bad U-joint could be the problem. Usually if it is it will also have a high frequency vibration.
It could also be bad bearings in the rear end.
It will probably take a trained ear to give you a better idea of the problem.
Originally Posted by bamaboy0323
do you have any idea how much that would costs. i mean the noise really don't bother me, but i would like to get it fixed before something worse happens. Hey thanks for the reply.
Your problem sounds similar to my post "Differential or tire noise". My truck has a similar sound. I heard from a mechanic friend that ford had problems with the differential making that sound and that there were some ford service bulletins on how to correct it. Has anyone else heard that? He had his gears changed under warranty. Let us know what the fix is, and how much it costs.
Originally Posted by hardrock47
i have the same thing wrong with my truck. I am going to try to dig in a fix it myself. Ill let you know how it goes
Maddog
Planejet42
08-02-2016 05:37 PM
Mr. SevenThree
12-21-2011 12:15 AM
hondo25
06-24-2003 08:17 PM
