What Company supplies your WVO system? - Ford Truck Enthusiasts Forums
Old 08-19-2006, 02:45 PM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
Has anyone purchased a kit from Golden Fuel Systems in Springfield, MO?
Or who is supplying you your kits and what web address do they have?
I am comparing WVO Kits.
Flea
Old 08-20-2006, 07:59 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Not sure were you live but if you live in a cold climate you will want a system that can provide both coolant bases heat and Electrical heat.
Plant Drive offers this.
We have coolant based heat for the entire system and Electric heat for various components.
The Hotfox fuel pickup and Vormax filter both use coolant heat. We also offer flat plate heat exchangers. All of our kits come with a Vegtherm, which is an electrically heated fuel tube you install just before the fuel entered the engine on it's way to the high pressure pump or injector pump if other then a Ford PSD setup. We also offer an Overnighter that can keep you Fuel filter warm so the oil will flow through it.
With a coolant only system your switch over times significantly longer since you have to wait for the coolant to get warm and then it need to unthaw your filter and get everything else up to 160F before you can switch over.
We also have kits specifically designed for the 2nd gen 7.3 and the 6.0 PSD.
Golden Fuel Systems v. BioFuels Technologies Vegistroke 7.3dieselMike Bio-diesel, Propane & Alternative Diesel Engine Fuels 23 12-31-2015 05:36 PM
water in my wvo? onthemoveactivist Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 01-13-2014 01:42 AM
Golden Fuel System WVO Kit...Anyone running this? FrontierGI Excursion - King of SUVs 0 04-21-2008 11:41 AM
Golden Fuel Systems? mudmaker Bio-diesel, Propane & Alternative Diesel Engine Fuels 10 04-21-2008 11:32 AM
Golden Fuel Systems stock front tank instal MaxRedD90 Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 04-06-2008 08:00 PM
Tags
mo, overnighter, springfield, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
