Norton V8 - 180 degree offset crank
#31
Thanks Penn Dick, but after seeing the pic I am even more convinced that there would be increased vibration thus requiring a bigger counter balance. And I would guess the more counter balance the less HP produced to the rear wheels. I am so confused. Why would anybody want to use this? Jag
#32
#33
Originally Posted by 4tl8ford
The Flathead has four rod journals, with two rods per journal, 1/5 - 2/6 - 3/7 - 4/8. (Just some basics)
With the Flat crank that puts journals 1/4 and 2/3 180 apart. That is the only configuration that i've ever seen or coul imagine.
With that, pistons 1 - 5 - 4 - 8 are at TDC while 2 - 6 - 3 - 7 are BDC
Dick
Dick
#34
#35
I have received a magazine article from a 1950s issue of Drag News that explains how this crank works.
The author says, ". . . it is in effect two four cylinder engines working in unison but firing alternately." The entire article can be viewed at http://www.old-fords.com/flatcrank%202.htm.
I would still like to talk to people who have run this crank.
I think the idea of this crank being part of an air compressor modification is not true, and unimportant.
Norton72
09-05-2019 02:40 PM
Norton72
02-13-2017 02:49 PM
Tom Norton
1983 - 2012 Ranger & B-Series
10-02-2012 11:40 AM
