Tune-up specs needed for a 352 - Ford Truck Enthusiasts Forums
Old 05-08-2002, 05:12 PM
dfox dfox is offline
dfox is starting off with a positive reputation.
Hi,
I don't have a manual yet for my new '66 F250 but it needs a tune-up
badly! What is the plug gap, point gap and timing for my truck?
('66 F250, 352ci, 4spd)
thanks,
Dave
Old 05-08-2002, 05:31 PM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
66 352 is as follows:
Plug Gap: .034
Points gap: .017 (set a .016 to allow for wear)
Dwell: 26 -31
Timing: 6 degrees
RPMs: 500 - 550
Old 05-09-2002, 11:11 AM
Thanks a million!
Do you have any recommendations for what service manual to get
or where to look for one. Are the "factory service" re-prints well
worth the $75 or is a used chiltons my best bet?
thanks again,
Dave
'66 F250 Camper Special
Old 05-09-2002, 11:29 AM
Dave, for starters, Chilton's is quite good. In fact, that's where I got the specs all in one place, and didn't have to search the big bulky volumes for them.
It depends on what kind of work you are doing to determine which books you need. Are you going to trick it up with after-market or later production modifications? Then interchange manuals might be a better bet. Others on this forum would have a better opinion on that, I think, because I am leaving mine mostly stock. The biggest changes I'll do to mine is add power steering, add front disc brakes, and change the 352 to a 390. For the major modifications like the brakes and power steering changes, I'll use the knowledge of the great folks on this board. Other stuff, it depends, and what I have access to I'll share as I can.
That doesn't mean that the original manuals won't be of some value, but $75 is a bit much, in my opinion. For example, I got the 1968 (and earlier) Ford Truck Service Bay Parts books (well-used, of course) for $50 on E-bay a while back, and got the original (yes, original) Service Manuals for F-Series for $35, all four or five volumes of it.
The deals are out there, just keep looking.
Good luck!
Old 05-09-2002, 10:03 PM
zukezake zukezake is offline
zukezake is starting off with a positive reputation.
I'll be scanning my copy of the owner's manual specificiation section. This is not something i've seen on the web site... I'll take the time now to quote the pertent info, though they agree with the prior poster
Compression presure - 160-200
Idle speed
Std transmission
Non-thermacator 550-575
thermacator 510-636
Auto trans (in drive)
Non-termacator 475-500
Thermacator 525-550
Oil presure hot (psi at 2000 rpm) 35-55
Cylinder Firing order 1-5-4-2-6-3-7-8
Sparc plug replacement number BF42
Plug gap .032-.036
Distribtor point gap .017
Ignition timming
non-thermacator
STD 6 (degrees) (3) (4)
auto 6 (degrees) (3) (4)
Thermacator
STD TDC(3) (4)
auto TDC(3) (4)
(3) if the individual requirements of the vehicle and/or use of sub-standard fuels dictate the inital timming may have to be retarded from the "pre-delivery" or "Normal" setting to elimate detonation. If retarding is nessicary it should be done progressivly not to exceed 2 (degrees) BTDC.
(4) For altitude operation and/or in order to obtain optimum engine performance and fuel economy it is permissible to further advance the inital tignition timming to a maximum of 5(degrees) in excess of the "mnormal" setting. No further improvement in engine peformance or fuel economy will be achieved by advancing beyond this point. To Pperform this operation the timming should be advanced progresively untill engine detonation (sparc knock) is evident under ideal road test acceleration, following which the timing should be retarded sufficiently to elmate detonation.
Old 05-13-2002, 03:43 PM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
DFOX,
I bught the CD-Rom manual for my 66 through the online store here. It's well worth the money, and if you need a page to take out to the truck while you're working on it, just print it out. If it gets filthy with grease, just throw it away. Try that with a print manual?
Just my .02
Kyle
Dayton, Texas
Old 05-14-2002, 06:28 PM
chickenmanq chickenmanq is offline
chickenmanq is starting off with a positive reputation.
Old 05-17-2002, 01:54 AM
... and if you need a page to
While this is a decent feature, imagine the feature of a passive indexing system where by the most commenly used pages are marked clearly with the fingerprints of the user there by forcing the documenation of all sections accessed and manipluated by the end user.
Actually I've made insurance clames based on this passivly indexing technique. they made the mistake of asking me if I bought parts for my car, and I could clearly state with 100% assurance each part purchaced based on my finger print etched on the page.
Actually, I'm a fan print your self manuals, provided they are printed on a laser, not inkjet. Though I only have one HP laserjet II series, and recently aquired a similar vintage TI microlaser plus, both being in the goodwill $20.00 catagory, they don't suffer from the ink smearage that lasers do.
Alternativly speaking, I know places like kinkos offer laser printing at a nominal cost per page, and possibly a cost per keystroke to peform the fuction, but hey.
Tune-up Specs Questions rpaxton939 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-07-2014 08:51 AM
1971 Ford F 250 specs TonyGalasso 1967 - 1972 F-100 & Larger F-Series Trucks 6 02-18-2013 02:48 PM
New member - 1965 352 tune up specs bagpype 1961 - 1966 F-100 & Larger F-Series Trucks 30 10-06-2011 01:46 PM
Tune-up Specs 223 engine F100 1963 jimstrecker 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-10-2009 08:48 PM
tune-up specs sledhead56 401, 477, & 534 SD Engines 3 06-18-2004 10:39 AM
Tags
1965, 1966, 352, engine, f100, f250, ford, gap, knock, plug, points, specs, truck, tune, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
