4x4 under $1000? - Ford Truck Enthusiasts Forums
4x4 under $1000?
Old 08-18-2006, 11:49 AM
mgdemarco mgdemarco is offline
mgdemarco is starting off with a positive reputation.
4x4 under $1000?
I've read these board for a while and have learned a lot; thanks for the great advice. Here is my situation: My daily driver is a 91' f150 lariat with the 302. I'm very happy with this truck except that it is 2wd so I can't take it through the Jersey pinelands and it is awful in the snow.
I'm thinking of looking for a 1980-1986 4x4 with the inline 6. I would like to spend under a $1000. It would not be a daily driver. I would use it in the snow and for fishing, canoeing, and exploring the pinelands.
I have learned a lot from my current f150 and I would have a mechanic friend look a truck over before a buy it. What do you guys think? Am I likely to end up dumping thousands into an old truck or is it likely that I could find an old truck that will not need tons of work? Thanks...
Old 08-18-2006, 11:11 PM
kawcrasher's Avatar
kawcrasher kawcrasher is offline
kawcrasher has a good reputation on FTE.kawcrasher has a good reputation on FTE.
There are plenty of these trucks still running around,some in pretty good shape.It shoundn't be to hard to find a decent one for around that price. I bought my 84 f350 crewcab 4x4 for $1100.00 off ebay. Just dont be set in stone on equipment or let looks keep you from buying a mechanicaly sound truck.
Old 08-19-2006, 12:40 AM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Yeah it shouldnt be too hard to find one it depends on where you live and how good condition the trucks in your area are.. for example is a lot of rust common in your area? good luck on your search
New Member - Looking to Buy Excursion MisterRam Excursion - King of SUVs 15 12-09-2016 08:07 AM
Thinking of swapping in a IDI Stephen67 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-12-2016 02:22 PM
Ford Edge buying advice Pgh Rebel Crossovers 22 05-30-2016 08:19 PM
More engine debate; Triton vs Cummins Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 12-11-2011 04:56 PM
Tires for 99 F250 235/85R16 or 265/75R16 kert2 1999 to 2016 Super Duty 21 02-20-2011 10:36 AM
Tags
1000, 1978, 2010, 4x4, canada, cars, cheap, daily, dollars, driver, f150, ford, jersey, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
